- Joel
- Apr 7, 2021
- 295
- 715
- 1,298
- Arizona
- Website
- www.stage3motorsports.com
- 2021 Bronco Badlands 4 Door 2.7L Ecoboost
- Badlands
Plenty of these in stock and ready to ship for anyone in the market, shoot me a PM.
2021-2022 Bronco Warn Elite Front Bumper 107870
Warn Elite Front Bumper Features:
Sharpen the look of your 2021-2022 4-door or 2-door Bronco with Warn's Elite Front Bumper with Grille Guard Tube. Finished in a perfectly flush flat black that'll mesh well with the look of your stock fender flares and side skirts, the Elite Bumper will instantly toughen up your Bronco. Pre-treated in a 5 step process with zirconium nanotechnology, the finish well help prolong your bumper's lifespan - even under extreme circumstances. Flat faces along the sides edges of the bumper provide excellent approach angles when you decide you want to take your Bronco off roading. Innovative design also allows for the fitment of oversized tires, making your Bronco an absolute trail killer. Recovering from off road scenarios has never been easier thanks to Warn's decision to included integrated jack points and welded eyelets for hassle free recovery operations. The winch mount alone makes this bumper and grille guard worth taking on any adventure. Recessed fog light housing allow for you to add your choice of fog lights to the bumper. Warn really thought of it all when creating the Elite Front Bumper with Grille Guard Tube.
Durable Boxed Steel Construction with Black Powder Coat Finish
Warn builds each of the Bronco Elite Bumpers from the ground up to survive tough challenges off-road while looking great for the life of your Bronco. The bumper is made entirely out of steel in a heavy-duty boxed design that can take hits that would leave your factory bumper in shambles. The flat black powder coat finish fits in perfectly with just about any Bronco paint color and styling theme, while also keeping the bumper protected from corrosion in nearly any application or climate. The included Baja Tube gives your Bronco's grille some extra protection from brush and other debris while also adding a mean, off-road ready look to your aggressive 2021-2022 Bronco build. The Elite bumper's winch mount plate features a standard 10x4.5" bolt pattern and was designed to accept Warn winches of up to 9,000lb capacities or other winches with similar dimensions. The Warn Elite bumper installs right into place of your Bronco's factory bumper with only minor trimming of the stock skid plate required (if equipped).
Fitment:
Will not fit Bronco Sport: this bumper will not fit 2021-2022 Bronco Sport models, and is only meant for 2-door and 4-door body-on-frame models.
Requires minor skid plate trimming: this bumper requires minor trimming of the factory skid plate (if equipped) for installation. See Warn's 2021-2022 Bronco Elite Bumper Install Instructions here.
Compatible Warn Winches:
Options: 2021-2022 Bronco Warn Elite Front Bumper w/Grille Guard
- Geometry designed to accommodate for steeper approach angles
- Perfectly pairs with oversized tires
- Integrated winch mount
- Recessed fog light housing
- State-of-the-art, zirconium nanotechnology treated flat black powder coat
- Integrated off road jack points
- This model DOES NOT include the optional mounted grille guard tube
Fitment:
- 2021-2022 4-Door Bronco
- 2021-2022 2-Door Bronco
- Warn VR EVO 8-S 8,000lb Winch (Synthetic Cable)
- Warn VR EVO 8 8,000lb Winch (Steel Cable)
- Warn Zeon 8 8,000lb Winch (Steel Cable)
- Warn Zeon 8-S 8,000lb Winch (Synthetic Rope)
- Warn M8-S M8000 8,000lb Winch (Synthetic Rope)
- Warn M8 M8000 8,000lb Winch (Steel Cable)
- Warn 9.5XP 9,500lb Winch (Steel Cable)
- Warn 9.5XP-S 9,500lb Winch (Synthetic Rope)
- Warn XD9 9,000lb Winch (Steel Cable)
- Warn XD9i 9,000lb Winch (Steel Cable)
