- Joel
- Apr 7, 2021
- 295
- 715
- 1,298
- Arizona
- Website
- www.stage3motorsports.com
- 2021 Bronco Badlands 4 Door 2.7L Ecoboost
- Badlands
2021-2022 Bronco Zone Offroad 2" Lift Kit ZONF1220
Bronco 2" Leveling Kit Features:
While Broncos come fully capable stock, Ford left a lot to be desired in terms of tire size. Lucky for you, Zone Offroad developed a 2" Lift Kit that will safely allow you to install tires up to 35 inches. This leveling kit immediately eliminates the forsaken factory nose-low rake that every SUV seems to come with these days without sacrificing overall drieability. Not only will the leveling kit make your Bronco actually look like an off-road vehicle, but slapping on a set of tires up to 35 inches will, in itself, drastically increase your Bronco's off-road performance. You can enjoy the off-road performance of your Bronco without sacrificing its ride quality, making this the perfect leveling kit for enthusiasts who still want to daily drive their rig.
Features Steel Strut Spacers & Preload Spacer
Zone's 2" Lift Kit is constructed of heavy duty semi-aromatic glass-fiber reinforced nylon resin for ultimate durability. Not only are the spacers tough, but they offer a clean OE appearance under your Bronco's wheel wells. The spacers come with high-quality hardware to ensure that your leveling kit lasts against any abuse you encounter on off-road trails. The spacers along with the elongated hardware replacements included in this kit, let you finish installation in as little as a few hours.
Fitment:
Specifications:
- Levels stance without sacrificing ride quality
- Offers front lift of 2" and rear lift of 1"
- Clears 35" tires
- Easy, top mount bolt-on installation
- Does not require disassembly of front struts
- Operates within limits of factory upper control arms
Fitment:
- 2021-2022 Bronco Base, Big Bend, Black Diamond, and Outer Banks Models
- Will NOT fit the Bronco Sport
- Will NOT fit Bronco models with Sasquatch shock package
- Will NOT fit Badlands, Wildtrak, or First Edition models
Specifications:
- Front Lift Height: 2"
- Rear Lift Height: 1"
- Max Front Tire Size: 35 x 12.50
- Max Front Wheel Size: 18 x 9
- Max Front Back Spacing: 5.5"
- Max Rear Tire Size: 35 x 12.50
- Max Rear Wheel Size: 18 x 9
- Max Rear Back Spacing: Stock
