- Joel
- Apr 7, 2021
- 295
- 715
- 1,298
- Arizona
- Website
- www.stage3motorsports.com
- 2021 Bronco Badlands 4 Door 2.7L Ecoboost
- Badlands
Now available for order on the web.
2021-2022 Ford Bronco RPG Off-Road Upper Control Arms BRAA0240
2021-2022 Bronco RPG UCAs Features:
If you are looking for a meaningful suspension upgrade that will show immediate off-road performance improvement, RPG Off-Road has you covered. Their newest line of suspension parts and accessories for the 2021-2022 Ford Bronco includes the 2021-2022 Bronco RPG UCAs. These control arms are designed to free up some space in your front suspension while adding more control and responsiveness on the trails. You will have the extra space in your front suspension for upgrading to aftermarket coilovers and shocks. While on your 2021-2022 Ford Bronco, these UCAs are easily able to be serviced by simply removing the stainless steel bearing carrier. There is no complicated disassembly that makes this suspension upgrade as convenient as it is practical. You will get all of the maximized wheel travel and articulation that you look for with premium aftermarket UCAs without the complicated build. Works with Aftermarket Coilovers
With the 2021-2022 Bronco RPG UCAs, you will have free reign to choose whatever aftermarket coilover package you would like to complete your off-road front suspension build. These UCAs are compatible with all aftermarket shocks and coilovers. Not only are these UCAs versatile, but they are stronger than your average control arms. Each of the components are constructed from aircraft grade billet aluminum including the 7/8" FK rod ends and 1" spherical bearings. All of the necessary grade 8 strength mounting hardware is included for a smooth and easy installation. For even better, more long-term protection, everything is anodized for a sleek appearance and added corrosion resistance. Beyond the finish, you can make these UCAs truly unique to your 2021-2022 Ford Bronco build and personality with the different color options. You will be able to choose from gold, orange, black, and blue.
Fitment:
Does Not Fit Ford Bronco Sport
- One vehicle kit
- Grade 8 Hardware
- USA Made FK 7/8" Rod-Ends and 1" Spherical Bearings
- Aircraft Grade Billet Aluminum Construction
- Anodized for appearance and corrosion-resistance
- Stainless steel bearing carrier is easily removed for servicing
- Works with stock and aftermarket coilovers
- Available with a 1" spherical bearing
- Does Not Fit Ford Bronco Sport
Fitment:
- 2021-2022 2-Door Ford Bronco
- 2021-2022 4-Door Ford Bronco
