- Joel
- Apr 7, 2021
- 295
- 715
- 1,298
- Arizona
- Website
- www.stage3motorsports.com
- 2021 Bronco Badlands 4 Door 2.7L Ecoboost
- Badlands
New RPG Tie Rod Kit added to the site.
2021-2022 Ford Bronco RPG Off-Road Full Tie Rod Kit BRAA0003
2021-2022 Bronco RPG Tie Rod Kit Features:
Off-Road suspension parts are essential for creating an unstoppable adventure vehicle. RPG knows this well and they have come up with a new set of tie rods that will transform the strength and performance of your 2021-2022 Ford Bronco suspension. The 2021-2022 Bronco RPG Tie Rod Kit features a hex bar design that is exponentially stronger than the existing units. It is an upgrade from the traditional round bar design that usually require flat cuts to be grooved on them. Doing so reduces the strength of the tie rods. The hex shape eliminates this practice, thus giving you stronger tie rods that the 2021-2022 Ford Bronco has been missing all along. For an off-road capable suspension, you can not forget about making this important upgrade.
Extremely Strong 17-4 Steel Construction
The steel used to construct the 2021-2022 Bronco RPG Tie Rod Kit is incredibly strong. Traditionally parts like this are constructed from 4130 chromoly steel, but the material used on these tie rods is 17-4 pins steel which is twice as strong as 4130 chromoly steel. The quality of these tie rods is out of this world for the price. Even better than the construction is the design. Many other standard tie rods have weak points in their design that makes them lose strength and proper functionality. The hex bar design of these specific tie rods yields higher stress concentrations making these tie rods the strongest the 2021-2022 Ford Bronco has ever seen. When it comes to off-road performance, you never want to skimp when it comes to your center pins controlling your steering.
Fitment:
- 17-4 Pins = 2x Stronger than 4130 Chromoly Steel
- FK Rod Ends
- Teflon Lined
- Hex-bar design
- 100% Made in USA
- Does Not Fit Ford Bronco Sport
Fitment:
- 2021-2022 2-Door Ford Bronco
- 2021-2022 4-Door Ford Bronco
