evilletruck
Bill
Evansville IN
2006 F350
Last video I did off road with the bronco ended with some unanswered G.O.A.T Mode issues.
Luckily this time around was much more fun and no random error codes to ruin the day.
7722 Bronco
Kentucky
2020 Explorer ST/ 2019 F350 CC DRW 4x4
Cool video. Glad to see you mudslinging!!! It's what they're built for, get out and enjoy them.
Vigor
Heaven on Earth
Total offrosding noob question here
If the water or mud line goes above the bottom of the door, can it find its way in? I imagine that the doors aren't liquid tight
KyleQ
Kyle
Twin Cities, MN
8 Broncos!
There is an official water fording depth that is listed somewhere. Typically water can go quite far past the bottom of the door seal line, I've had water approaching the door handles on 90's trucks that didn't ingress water through the door seals.
What tires were those, they didn't want to clean out that clay like mud no matter the wheel speed, must steer clear of those!
UNBROKN
Central Virginia
04 F-350 CC dually, 97 Infiniti QX4, 21 Bronco BD
What steps are those on there? I like them. Look like some kind of rock slider/steps. They are small and look like they do not hang down at all.
UNBROKN
Central Virginia
They are pretty tight. The Bronco can go through water up to 3 ft deep I think.
Gourik31
JJ
Stof
evilletruck
evilletruck
Bill
Evansville IN
2006 F350
They are bodyguard rock sliders did an install vid on them here
Greens05
Andrew
Harrisburg, PA
Jeep TJ, BMW 335xi
Curious what the criteria is for maximum water fording depth? I would have thought it meant the depth that the truck would continue to run (air intake height and breather valves etc)...not necessarily the depth that there wouldn't be any water in side the cabin. I don't really know for sure though.
Paul Gagnon
Paul
Sherwood Park, Alberta, eh?
'79 Mustang, '92 Explorer, '10 F-350
It depends one how long you are sitting in the water. Move through without stopping and it generally isn't a problem. Stop for an extended period of time or get stuck and it will get in.
