creeohdee
Threw on a bunch of lighting upgrades
From Oracle:
Oculus Bo-LED Projector Headlights
Flush LED Taillights (not pictured/requires Forscan)
Mirror Ditch Lights
Interior Fiber Optic LED Kit
I also added on some KC Fog lights in the bumper and already had RIDGE 360 Ditch Lights installed as well
All in all everything came out great. These Oculus headlights are kinda wild, had to adjust them a bit bc it’s like having two neutron stars on the front of your vehicle causing oncoming traffic to careen off the road and burst into a fiery wreck, but after that they work great.
Ford Bronco Lighting upgrades Bronco OBX BE42B219-20BD-41B7-A314-D997591B0ADF
Ford Bronco Lighting upgrades Bronco OBX 168D1FB2-C433-4E87-8224-A2858A85A9DC
Ford Bronco Lighting upgrades Bronco OBX 83C2E806-4E18-464F-AC85-ED968644249B
JayGar562
Jay
LBC, CA
23 Bronco Black Diamond
Looks good! I’ve been eyeing those headlights. How was the install?
rpaluch1
Rudy
Tecumseh Mi
Ford Bronco
Where did you purchase the interior LED kit ? How difficult was install and how flush is it on the panels?
AntiMatterSAS
Jr
2021 Bronco base SAS 4 door 2.7
Love it! Clean and simple🤘
U originally had signature headlights?
creeohdee
creeohdee
Super easy, just plug’n play. Getting the grill and everything off was not difficult either. Im really pleased, they have a very unique look to them.
creeohdee
creeohdee
creeohdee
creeohdee
I got everything here from Stinger Offroad, however I believe the lighting kit is out of stock currently (I work with them so you can actually use code CREE for a discount)
The install was interesting. Some places (the corners) didn’t exactly hold like I wanted and had a tendency to pop out a little but over time the fiber optic has stopped fighting where I wanted it to be and doesn’t pop out anymore. My main issue was hardwiring it in. Someone more capable of me could figure it out but I went right by their instructions and could not get power to this thing for the life of me. I rewired it back into the cigarette lighter for the time being.
creeohdee
creeohdee
Selling your signature Headlights by any chance?🫣
I was considering it but I’m going to hold off for a bit, I want to make sure that I wanna stick with the oculus ones before I get rid of them
AntiMatterSAS
Jr
Respect🦾
Pm me if you change your mind
rpaluch1
Rudy
Tecumseh Mi
Ford Bronco
Thanks I appreciate the code. I have a couple of installation question as your light tubes have great color consistency. On the lower level of your panel it appears your tubes end before the sharp bend above the start button ? Did you end light both ends of the tube ? And if so how did you handle it around the steering wheel area ? Thanks again I’m asking because your end result looks awesome.
creeohdee
creeohdee
No so I actually just ran the tube back behind the steering column, from that angle in the photo it’s hardly noticeable but in person you’d be able to see the tube running back there. Still doesn’t look bad at all when you look at it.
The issue is actually with the ends that run behind your grab handles. When you screw the grab handles back on they pinch the tubing and prevent the light from traveling through the fiber optic which makes the color weaker and less uniform. I actually just took a knife and cut out two small notches on the bottom of the grab handle (didn’t need it on the top) so the tubing could run through it without being pinched. You can’t notice it at all.
rpaluch1
Rudy
Tecumseh Mi
Ford Bronco
Thanks I appreciate the feedback and info on the grab handle area. All good to know.
Shazamalingo
West
2022 OBX SAS
Where did you get the amber lights in the grill? I’ve been wanting grill lights, but the OBX grill doesn’t play nice with a lot of kits it seems.
cmbyrd77
Cory
Orlando, FL
Our builds are very similar! Are your interior LED’s on an Aux?
