B&O upgrade for the clueless ?
john2127
Georgia
2021 Bronco Badlands Sasquatch/2018 F-150 Platinum
My wife has the B&O system in her 2021. I want to upgrade the speakers but I know less than nothing about car audio. My plan is to upgrade the speakers first then later add another amp (or replace the factory one) and add a better sub. I want to be sure that whatever I change now is compatible with later changes. The salesperson at Crutchfield suggested I do component speakers for the kicks and use the tweeters to replace the corner dash speakers. I'd also like to upgrade the roll bar speakers to 6.5 with an aftermarket pod.
My initial questions for the experts are:
1. Has anyone used tweeters for the corners? Are you happy with that change? Does that require any reprogramming/Forscan?
2. Similarly does changing the roll bar to 6.5 require reprogramming/Forscan?
Thanks in advance everybody.
LAB0035
Lex
2022 Ford Bronco Badlands
I went with Polk audio speakers. The price is not bad plus they are marine rated . used mabett rear speaker pod to upgrade to 6.5 speakers . i used sound deadner in the pods and the kick panel + sub box. no forscan req. , opted out of adding Amps. i did not feel the need to anoy people in traffic
john2127
Georgia
Thanks for the help. Which Polk speakers did you use?
L&Ebronco
Oklahoma
94 bronco, 18 F250
Mti acoustics makes a plate for dash to change from 4” speaker to a tweeter. Do a search on here as well. I’ve read a few times people saying you do need to make some changes w forscan of the rear pods if you change to a 6-6.5” speaker bc that pod is set for a high pass filter. So you won’t get the full range of sound from it. https://www.mtiacoustics.net/ford.html#!/2021-Bronco-Tweeter-Plates/p/451785661/category=127527301
john2127
Georgia
Thank you very much.
