Broaddict trail deck installed
TXAstro
Everglades
Trevor
Bronco Everglades
Everglades
Thanks for the tip. I did not think of that. Better research the safety factor.
Run3gun
Anthony
2023 Bronco
^This^...shorten the deck to flush where the handle mounts and it would work with just about any tailgate table. Probably done intentionally so they can sell more of their tables.
Also, IMO the handle is useless...when I pull out the deck or drawer I simply unlatch both sides simultaneously and pull. Makes no sense to me to unlatch and then use the handle.
As requested. Here are some shots of my Broaddict TrailDeck and shelf. You can see that I used boat decking (peel and stick on) to cover my sound deadening and to give it a nice clean look.
Ignore the amps in the cargo floor. I just started an install and haven’t made a proper amp board. I have a Musway M6 Pro DSP mounted to the underside of my rear drivers side seat. The person plug popping out from under the rear seat is a quick disconnect for my downfiring sub enclosure. I wanted a simple option to remove it and not leave bare speaker wires laying around.
Just got my boat decking from Amazon
I’m gonna install when the the Broaddict
Tailgate table gets here later this week
Stay tuned for more pics .
DBGBronco
Justin
Kamuela
24 BDSAS
If you remove their handle and replace with a soft handle will it then work with a tailgate table?
My question too…. I have the bison gear table and don’t want to lose it. The new BROADDICT version looks like the slide out would go below it.
Deadpool392
New Bern, NC
2025 Marsh Gray Bronco Raptor, 2020 Gator JTR (retired)
I am also waiting on my new BroAddict tailgate table to be delivered, it should be here this week and I can then take some measurements for those wondering how it compares to existing options.
Mibuckeye
Grass Lake, MI
2021 Ranger Tremor
Rumor has it that the slides may be changing to true bearings instead of standard drawer hardware. Anyone with new ones see this yet?
Deadpool392
New Bern, NC
Here are some photos with the measuring tape of the new table and how much room it gives with the TrailDeck.
Ford Bronco Broaddict trail deck installed IMG_1737
Ford Bronco Broaddict trail deck installed IMG_1738
Ford Bronco Broaddict trail deck installed IMG_1739
DBGBronco
Justin
Kamuela
24 BDSAS
Is that BROADDICT’s new table for the Traildeck?
Run3gun
Anthony
2023 Bronco
mine came about 2 weeks ago and standard drawer hardware !
Mibuckeye
Grass Lake, MI
2021 Ranger Tremor
Was told by the Broaddict team that they are looking at replacing the slides with full roller bearings to eliminate the metal on metal current slides. Just wondering if they had released it yet. My Traildeck is currently on the floor in my garage after being removed due to my inability to fit my Packout gear in the way I want and my disdain for rattles and squeaks. Ive mounted a packout mount to the floor and Ive got to say it is way quieter with it the way it is now. No rattles. No squeaks. Broaddict has gone AWOL on addressing the noise concerns and has just told me that the noise is common and expected with the slides they are currently using; that I should just stuff some rubber in the back to close the gap. So, it sits until I figure out which way I want to go.
Run3gun
Anthony
2023 Bronco
As requested. Here are some shots of my Broaddict TrailDeck and shelf. You can see that I used boat decking (peel and stick on) to sound deadening and to give it a nice clean look.
It’s not really a carpet just removed the trunk pad this need to be removed for the slide and the seats to be level. You could buy some after market carpet or felt to put down or even raptor line it . Endless possibilities. Left mine bare and doesn’t bother me not even a
little bit . I also insalled a BLUETTI charger 2 in the cutout that needed to breathe so the slide deck for me serves many purposes.
update so when I said it didn’t bother me not even a little bit I’m pretty sure I lied to myself
Anyway it looks finished ! Lol!
Check this out - or ask Alexa, your shopping assistant for more ideas
https://a.co/d/0bHviSZR
Ford Bronco Broaddict trail deck installed IMG_8382
Ford Bronco Broaddict trail deck installed IMG_8386
Ford Bronco Broaddict trail deck installed IMG_8387
DaddyO
Jules
Austin, Texas
2024 Bronco 4D 2.7L Sasquatch
I wish Broaddict would come up with an updated design which is 1 to 1.5in shorter to allow compatibility with existing tail gate tables. I would buy one immediately, but can't justify losing my existing table ($250) then spending to $$$ buy this version and another tail gate table. Odd that they didn't consider this during the initial design. There are likely others similar to me.
They knew it wouldn't fit with the pre-existing tailgate table. I was one that was involved with questioning them as to why they weren't going to make it a few inches shorter to accommodate the current owners of their tailgate table and they didn't respond to it except to respond for us to buy the new table so it would fit. no response as to what to do with the older tables. I even suggested they take them back as a trade in on the new ones.
DaddyO
Jules
Austin, Texas
While I think that helps with some, I don't believe it will solve the problem with all tail gate tables. I don't think it will work with my Broaddict tail gate table. I found it odd that it isn't compatible with the pre-existing Broaddict tailgate table.
see my previous response, they knew.
Run3gun
Anthony
2023 Bronco
Ford Bronco Broaddict trail deck installed IMG_8400
Deadpool392
New Bern, NC
That looks clean! Depending on what the pad BroAddict sends out looks like, I may do the same thing.
