Bronco Fishing Rod Holders - 50% OFF!
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
In case you are not aware we have some of our Fishing Rod Holders on sale at 50% Off. These are clearance items as our powder coater messed up the paint job and went REALLY heavy on the paint. So we're selling them at a HUGE discount. Only the double holders are available (which are our most popular).
Grab a set here: https://www.4x4truckleds.com/kr-off-road-fishing-rod-holder-for-2021-ford-bronco-clearance/
If you're a fisherman looking for a place to mount your fishing poles, look no further! Designed here on Long Island, NY (surf fishing capital of the world) this mounting system provides a simple and elegant solution to a common problem. That problem... Where do you mount your fishing poles on the Bronco?
Utilizing the existing mounting points on the front of the truck our stainless steel bracket system provides a secure and stable system to support 1 or 2 rods (per side). Each holder is designed to safely and securely hold your fishing pole without damaging it. The angle of the mounting system allows you to transport long fishing rods without the fear of snagging an over-pass or electrical line. The rods sit at an angle hovering over the roof line to ensure your rod does not hit the roof during transport.
Simply bolt on the system, slide in your fishing pole and head to your favorite fishing spot.
Ford Bronco Bronco Fishing Rod Holders - 50% OFF! 40-2003D_4
Ford Bronco Bronco Fishing Rod Holders - 50% OFF! 40-2003P_4
