Custom Hood Decal Concept -Xanthus
Snydermann
Tim
South East, PA
Samurai, VW Thing, MINI, smart, Astro Van
Jdegid_SoCAL
Coto De Caza , CA
Tesla , Jeep Wrangler
Did you create the hood size Base template? I have Illustrator and a 24" Roland cutter mind sharing the base only template?
Travelingchef
GA
Volkswagon Tiguan
Xanthan gum is a food additive.
Actually it comes from trees and is natural. It holds and binds many snacks, sauces, it is also used to keep your favorite dressings from separating.
CUPRA
CUPRA
'21 Bronco OBXSAS/'23 Camaro SS Convertible
Yes, I created this template. This test cut is scaled down for proof of concept. I haven’t created a full size template yet. Probably this weekend.
CUPRA
CUPRA
So, this weekend, I went ahead and created the full size graphic and installed it on the Bronco. After the comments here, I did revise the ‘X’ to define it a little better.
Turned out nicely for a DIY job, ended up installing really easily and so smoothly too.
Here are some pics and a time-lapse video.
CKXVII
CK
F-150
Prior to picking up our Bronco, I purchased a semi-professional vinyl cutter as I wanted to have some fun with decals and graphics on it.
My wife and I finally decided upon a vision, I designed it, and then test cut a small scale version this afternoon. I am beyond excited with how it turned out.
Based initially on the Wildtrak matte black and gloss black hood decal, it’s matte black with our gloss black ‘XANTHUS’ logo, and then a topographic element with a steampunk inspired skull in the middle of it.
Can’t wait to get the full size one cut out and installed. Here are some pictures of the small scale test and design.
Ford Bronco Custom Hood Decal Concept -Xanthus 445FC37B-39F5-4638-99F7-E3B08E51AF6A
EDIT: Full size graphic has been installed now, with a couple of tweaks mentioned further down in this thread.
Have you experimented with adding an additional transparent layer on top (the size of the matte black base layer)? I did a somewhat detailed gloss black topo design on a matte black hood bump decal and was wondering if adding a transparent layer could act as a ‘sealant’ so that you don’t have to be as cautious with cleaning the ‘design’ layer. Mine has held up well over the past 3-4 months, but I cringe every time I go to clean it.
CUPRA
CUPRA
I'm absolutely there with you! The 'XANTHUS' is fine, I can clean over that no problem at all. But the top design is having issues with a cloth dragging on it. I've considered peeling off the gold, and recutting it, without any points on it at all, making all the edges rounded. That way there's nothing to snag on.
Alternatively, as you say, a clear layer over the top might not be a bad idea either. Might be worth a try too. At the end of the day, it's only vinyl, if I mess it up, I can do it over, as I cut it all and install it myself.
RCVBAF
Brett
Caddo Mills TX
2020 Explorer, 2005 Ranger FX4, & 2021 Bronco
That looks awesome! I’ve been wanting to do something like that. turned out great.
wetdog
Bruno
pacific coast
2019 jl
That would make mine "hokey"
Ford Bronco Custom Hood Decal Concept -Xanthus 20220511_183156
GO_SOONERS_TXSUX!
Jake
4Runner
Badass
