- Adam
- Aug 30, 2021
- 355
- 4,381
- 5,844
- Lindenhurst, NY
- Website
- www.4x4TruckLEDs.com
- 2018 Raptor & 2021 Bronco Outer Banks
- Outer Banks
https://www.4x4truckleds.com/diode-dynamics-stage-series-ss3-ditch-light-kit-for-2021-ford-bronco/
The Diode Dynamics SS3 Ditch Light Kits are now in stock here at 4x4TruckLEDs.com - You know how we do it here, so we took this kit and bumped it up a notch.
Since we stock all of the SS3 lights we're allowing you to select which lights you want. Choose between Sport, Pro or Max in 10 different lens options (NOTE: The Max Yellow are only available in an SAE Fog pattern, however the Max White are available in all 5 patterns).
SAE Driving is designed to supplement your high beams, but it’s great for general illumination as well. Rather than a traditional "spot" pattern, the Stage Series Driving pattern shines in an 18x8 degree spread, providing just enough width to fully illuminate the road ahead at high speeds.
SAE Fog provides an extremely wide field of view, with high-intensity output over an entire 80-degree spread. It serves as a great upgrade for any factory foglamp, and will fully illuminate the area in front of your vehicle. Choose your output color of cool white or yellow, which is often said to help cut through inclement weather.
Flood pattern was designed to provide uniform, even illumination with a full 60x60 degree spread of light. Unlike generic "flood" lights that are simply a heavily diffused spotlight, our flood pattern uses pillow optics on the outer lens surface, to provide a true optically designed spread, for even illumination throughout. It is perfect to use as a backup light, for lighting up anything at low speeds, or for trailers and worksites.
Combo pattern combines both the Driving and Flood optics. It shines light downrange in a focused, rectangular 65x25 degree pattern. The combo lens features a flood optic on one side and a driving optic on the other.
Spot is an unmodified pattern, shining light directly from the TIR optic. The result is a highly focused 6-degree beam of light, perfect for directing light far into the distance. With an incredible output of 151,000 candela, the SS3 Sport shines a half-mile away (ÂĽ lux), from a compact 3-inch package.
Each kit includes the following:
- Two (2) SS3 Standard LED Pods
- One (1) OEM Auxiliary switch harness
- One (1) Light-duty dual-output harness
- Two (2) Mounting Brackets and hardware
