Driver side window wobbles upon opening
margareedaville
'22 Wildtrak
Last night I noticed that when I open my door, the dang glass makes a wobbling sound. Almost like the rubber support on the hinge side isn't stabilizing it. Passenger side is tight. Anyone else have this issue?
j_anderson
Fort Wayne, IN
www.instagram.com
mine is the opposite. Driver side is tight, Passenger wobbles
FifthCard
Allen
US
Jeep Wrangler Rubicon
Both my rear doors do this. In fact the driver side is so loose that it doesn't seal properly against the rubber and allows water / air in. Talk about wind noise ..
Gilligans_off
Vince
Canada
2022 2 Dr Bronco Badlands Sas/lux
there are two 10mm bolts you can loosen with the window down to draw the window in tighter to the window seal. I'll see if I can grab a YT link...
this is the one that I found
FifthCard
Allen
US
I can't believe I never seen this. I am doing this tomorrow as it will be dark when I get home today. I will report back.
Stick in the Mud
Saco, ME
2023 Bronco Badlands
There’s a TSB for it. Basically just remove the rubber plugs on the bottom of the door, use a 10mm socket to loosen the nuts slightly, move closer to the outside of the door, tighten. Make sure they align with the plastic guide in the corner. Further out isn’t always better.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there. Can you send us a DM with your VIN and dealership info? I can look into this for you.
margareedaville
margareedaville
'22 Wildtrak
Not sure we're on the same page. I don't have a rattle while driving. In fact it is tight when the door is closed. My problem is that it wobbles very loosely upon opening the door.
Gilligans_off
Vince
Canada
Ford Bronco Driver side window wobbles upon opening 1674831820236
still a window adjustment you can try. Might help, might not. But the price is right and it’s quicker than a trip to the dealer IDK
djdearing
DJ
Austin, Texas
2022 2 Door Bronco
I have the same issue with my Bronco and it has seem to have gotten worse over the years. When I open the door the windows flops back and forth and makes an awful noise. I'm embarrassed to even park near people. Happens when getting in and out of the thing. I tried the window adjustment on the bottom but that did nothing.
Any resolution? Dealership says I don't have any TSB's.
rgraphic
R
Seattle
What do you mean by aligning with the plastic guide in the corner?
