- Mar 17, 2022
- 83
- 224
- 398
- Riverside, California
- Website
- dv8offroad.com
- Bronco's & Jeep's
- Badlands
2021-22 FORD BRONCO | A-PILLAR POD LIGHT MOUNTS
Our Bronco A-Pillar Pod Light Mounts were designed to match the MIC (molded-in-color) trim pieces found on all models. Our goal was to create light mounts that looked as if they came installed from the factory, maintaining the Bronco’s same bodyline style.
Up to 2 standard, 3-inch LED pod lights can be mounted on each side. Alternatively, a single larger pod light can be mounted on each side. We tested pod lights up to 6-inches in diameter. These can be used for forward facing lighting or as ditch lights. Because we gave them 3 mounting holes each, you can even fit (3) 2-inch pod lights if that’s more your style.
Check them out here: https://dv8offroad.com/collections/...ets/products/bronco-a-pillar-pod-light-mounts
Key Features:
- Pair of Light Mounts
- Up to (2) 3” Pod Lights, (3) 2” Pod Lights, or a Single 4”-6” Pod Light Per Mount
- Micro-Texture Black Powder Coat
- Matches OEM Trim Style & Appearance
- Utilizes Factory Hardware for Installation
- 3 Available Light Mounting Locations Per Mount
Visit https://dv8offroad.com/pages/ford-bronco-bumpers-and-accessories to shop all of our Ford Bronco Parts and Accessories.
Plus... use code "ForumMember" at checkout for 10% off!
