DV8 Offroad | Front Door Pocket Molle Panels
DV8offroad
Riverside, California
dv8offroad.com
Bronco's & Jeep's
2021-2022 FORD BRONCO | FRONT DOOR POCKET MOLLE PANELS
Our 6th Gen Bronco Front Door Pocket Molle Panels are the perfect accessory for anyone looking to add a little extra storage and utility to their vehicle. Made from rugged steel, these panels create larger door pockets and serve as a direct replacement to the factory door nets. You can store items inside the pockets, and molle accessories can be mounted on the outside of the panels.
The panels are also designed to hold a water bottle - something that was missing from the factory net. Installation is quick and easy utilizing factory hardware, and the panels are compatible with all 2- and 4-door 2021+ Bronco models. Increase the utility of your Bronco interior with our front door pocket molle panels.
Key Features:
  • Includes Front Driver & Passenger Side Panels
  • Increased Door Pocket Storage
  • Uniquely Shaped to Fit a Water Bottle
  • Multiple Molle Accessory Mounting Options
  • 2mm Steel Construction
  • Micro-Texture Black Powder Coat
  • Bolt-On Installation Utilizing Factory Hardware
Check it them out here: https://dv8offroad.com/products/6th-gen-bronco-molle-panel-door-pockets
Technical Specifications:
  • Fitment: Direct Fit
  • Material: 2mm Steel
  • Finish: Micro-Texture Black Powder Coat
  • Weight: ≈ 5 lbs
Visit https://dv8offroad.com/pages/ford-bronco-bumpers-and-accessories to shop all of our Ford Bronco Parts and Accessories.
Plus... use code "ForumMember" at checkout for 10% off!
RC Bronco
Rob
Kansas
'22 Ford Bronco, '97 Geo Tracker
These look slick! Got a few questions for ya:
- Is a set for the rear door pockets in the works?
- Is it safe to assume the factory net can be used alongside these as can be done with other variants of this (M2M, etc)?
- Do the doors still fit in the door bags and in the back of the Bronco with these on?
DV8offroad
DV8offroad
dv8offroad.com
Bronco's & Jeep's
Q #1 – Yes, we will have rears as well
Q #2 – We recommend not using the net for best fitment, but yes, the net can be used.
Q #3 – We have not checked if they will fit inside the bags. This is something we can check and verify once we get a hold of a set of bags.
ar1
Norcal
4dr WT
Can you confirm that this will accommodate a nalgene waterbottle?
lakesinai
Charleston SC
The webbing separates from its frame easily. The webbing then nicely installs between the DV8 and the door, which I did on passenger side only. Drivers, I installed a pvc flashlight holder.
