- Caleb
- May 3, 2022
- 142
- 578
- 461
- St Louis MO
- 2021 Bronco
- Outer Banks
Looking for power steps? Now is the perfect chance to save on AMP Research!
For a limited time, we have these step systems on sale $1525 out the door! Free shipping included!
Message me if you are looking to take advantage of this deal or have any questions!
AMP Research 2021+ Bronco Powerstep Side Step System
AMP Research invented the PowerStep™, the automatic, electric-powered running board that instantly extends when you open your door, and retracts out of sight when the doors close for improved ground clearance, aerodynamics and appearance. Its sleek design, all-weather performance and legendary reliability set the industry standard. PowerStep™ has die-cast aluminum alloy components and precision stainless steel pivot pins for rock-solid stability. The original PowerStep™ is American designed and engineered.
FEATURES
Automatically deploys and retracts to make getting in and out of your vehicle safer and easier
LED LIGHTING
Low-profile integrated LED light system
DURABLE BLACK TEXTURED FINISH
Step anodized and PTFE coated military-spec finish that resists corrosion and wear and tear
INSTALLATION
Includes all hardware necessary for installation. The product comes with easy to understand vehicle specific installation instructions. Be sure to read and precisely follow the provided instructions when installing PowerStep™ Power Running Boards.
WARRANTY
Backed by a 5 year/60,000-mile warranty
FEATURES
- The original electric-powered running board
- Automatically deploys and retracts
- Corrosion-resistant die-cast aluminum construction
- Heavy-duty stainless steel pivot pins
- Military-grade black PTFE coating
- 600LB load capacity
- 6-inch wide, cab-length steps
- Textured, slip-resistant step surface
- Low-profile, integrated LED courtesy lights
- Includes vehicle-specific installation guide and mount kit
- Includes patented Plug-N-Play module on applicable chassis
LED LIGHTING
INSTALLATION
WARRANTY
