Forscan help in LA
Quincybmx
Quincy
Just installed some 33” on my base and was curious if anyone in the area had Forscan to help adjust the speedometer? Thanks!
luntz
Greg
Los Angeles
2006 Jeep Rubicon Unlimited LJ
I'm planning on scheduling a Panda Motorworks Forscan session.
Getting the Sport Mode activated and Deactivating Autostart/stop are my primary reasons.
A friend has a laptop PC, I'll just need to order the cable and install Forscan on his laptop.
https://www.pandamotorworks.com/col...ts/panda-motorworks-approved-327elm-connector
We can share the hardware if you like. I'm in the Sherman Oaks area.
You'd have to schedule your own Panda session.
Desert_Brush
SoCal
2015 Mini Cooper
What part of LA? I'm in LA County, but about an hour away from LA City. I have a laptop, pc and the cable if you want help. I also upgraded my base 30" pizza cutters to some 33" wide bois.
luntz
Greg
Los Angeles
I'm in the Sherman Oaks area. I can drive to your location.
Would love your help. Did you program it yourself?
Desert_Brush
SoCal
2015 Mini Cooper
I did program it myself. It did take some trial and error, but I was able adjust the tire diameter size so the speedometer and odometer are more accurate. I'm located in Santa Clarita Valley (originally from "The Valley") so not that far from Sherman Oaks on a weekend since during the week you would probably walk faster than the traffic on the 405.
luntz
Greg
Los Angeles
Desert_Brush, Have you tried any other adjustments to the factory Forscan settings?
Such as adding a GOAT mode or disabling Auto/Start/Stop?
derichio02
Bo
Southern California
Bronco Badlands, Maverick, Tesla M3, F250 Tremor
I have turned on Bambi Mode, disabled double honk, adjusted the steering wheel temp etc but I’m even farther away in Palmdale though
Desert_Brush
SoCal
2015 Mini Cooper
I also disabled the double honk, start/stop, seat belt alarms for the front seats and added the Mud/Ruts drive mode.
derichio02
Bo
Southern California
I also programmed my Raptor lights to run with the DRLs as well. (The three lights on the Raptor)
mannyjag
Manny
SoCal
Hopefully one of you can help, I am in Santa Clarita and need help with my audio, I installed 6.5 speaker pods in the rear and need assistance on converting them from pods to speakers with forscan. is this something you guys can help with?
