I've found someone selling 4 fox coilovers from a 2023, 4 dr, Wildtrak. Can anyone tell me if these will fit my 2021, 2 dr, Wildtrak without needing new UCAs?
Yes, It will fit with no additional modifications. The rear springs will be a higher spring rate than the 2 door due to the additional weight of the 4 door.
The 2dr and the 4dr appear to only be about 250 pounds different - I would expect that the stiffer spring rate won't be super noticable? When I take it offroad I'm usually loaded with camping equipment so maybe the stiffer spring rate will help a bit.
BTW, thanks for your response!
