Rough Country Power Running Boards
Dual Electric Motor | 4 Door | Ford Bronco 4WD (21-24)
Asking $700.
Located in Aldie, VA 20105.
Drop From Rocker Panel (in): 5.13
Weight Rating (lbs): 600
Asking $700.
- 6” all-season, lightweight, durable aluminum running board.
- Dual-motor technology delivers maximum power when deploying or retracting.
- Anti-slip surface provides a secure stepping area (textured coating)
- Integrated LED lights illuminate the board when deployed.
- Automatic ‘SAFE-STOP’ engages if blockage is detected.
- Interior bypass switch for manual override.
- Retracted running board protects rocker panel.
- 660 lb. weight capacity per side.
- Easy, no-drill installation.
- Tucks tight under Rocker Panel for a clean, in-line look
