IN STOCK: Form Lighting 2021-2024 Ford Bronco LED Projector Headlights
chris@pandamotorworks
St. Louis
2016 F250, 2013 Ford Focus ST
Ford Bronco IN STOCK: Form Lighting 2021-2024 Ford Bronco LED Projector Headlights unnamed (2)
Features:
  • Direct fitment for 2021+ Ford Bronco
  • Adds selectable amber or White LED DRL
  • Aggressive, blacked-out appearance
  • Sequential Turn Signals
  • Quad-LED projectors for increased headlight performance
  • Modern Startup Sequence
  • 100% Plug-and-play installation
  • DOT compliant
Ford Bronco IN STOCK: Form Lighting 2021-2024 Ford Bronco LED Projector Headlights fl0020_ford_bronco_form_hl_kit_1
Ford Bronco IN STOCK: Form Lighting 2021-2024 Ford Bronco LED Projector Headlights 2021_form_bronco_headlight_comparison_collage
Ford Bronco IN STOCK: Form Lighting 2021-2024 Ford Bronco LED Projector Headlights 2021_form_bronco_headlight_high_beam_output_collage
Ford Bronco IN STOCK: Form Lighting 2021-2024 Ford Bronco LED Projector Headlights 2021_form_bronco_headlight_low_beam_output_collage
Sequential LED Headlights from Form Lighting are the perfect way to upgrade your 2021+ Bronco. With these premium OE-grade replacements, you’ll add sequential turn signals, a unique startup sequence, a diffused DRL in white or amber, and a more aggressive, blacked-out appearance.
Increased Light Output. These headlights feature four LED projectors, which provide increased output for both low beam and high beam. The top two projectors function as your low beam, while all four projectors function as your high beam, providing a sharp, strong beam pattern to illuminate the road ahead.
Startup Sequence. These headlights are packed with the latest and most modern lighting functions, including a unique startup or “welcome” sequence. Anytime the running lights turn on, they will illuminate in a sweeping pattern across the entire lamp, gradually increasing in intensity until it fully illuminates.
Sequential Turn Signal. The startup sequence isn’t the only thing that stands out. These headlights also feature an integrated sequential LED turn signal. Every time the turn signal is activated, amber LEDs in the horizontal bar activate in a smooth, chasing sequence. When you’re finished making your turn, they automatically “switch back” to your chosen DRL color.
Selectable DRL. These headlights feature a selectable DRL with a clean diffused optic, that allows you to choose between cool white or amber. Best of all, you can switch colors easily using a simple connector. There is no need to take the headlights off the vehicle!
OEM-Grade Construction. Form Lighting headlights are built with quality in mind, using OE-grade materials and design techniques. This includes durable UV-coated polycarbonate lenses, automotive-grade LED emitters, breather vents, and OEM plug-and-play connectors. They are assembled in an IATF 16949-certified facility, which is a quality management system designed for the automotive industry. While they may not be the cheapest option you’ll find, you can rest assured that these lights will provide durable and superior performance.
Road Legal. Form Lighting headlights meet all SAE, DOT, FMVSS, and CMVSS standards and regulations for legal on-road use in the United States and Canada, when installed and aimed properly - which is easy to do with the integrated screw-type adjusters.
Plug-and-Play. Our headlights for the Bronco are completely plug-and play for for simple installation. They were designed to plug into your factory headlight connector, and they fit perfectly without any gaps. No errors, flickering, or hyperflashing!
Two-Year Warranty. All Form Lighting products are rigorously tested for reliability, and backed by a two-year warranty. The warranty is supported directly by Form Lighting, and any replacement parts, if needed, are shipped quickly from Form Lighting’s US warehouse. On the rare occasion that you may need to utilize your warranty, we try to keep the process as simple as possible - for example, no return is normally necessary.
IN STOCK & SHIPPING FOR $1399 11/14/2023!!!
CLICK HERE TO BUY TODAY!!
Caleb@PandaMotorworks
Caleb
St Louis MO
We're lucky enough to have had these on our Bronco for a while now, and we absolutely LOVE THEM!
Super excited to finally have these released and share with your guys! :)
TEAMSLO
NV
youtube.com
23' Bronco 2.7 4d Oxford White (sold) & '23 Jeep 392
Not trying to be a smart*ss here. What's the difference between these and the other brand?
St. Louis
the biggest difference I see is the lower entry point for the same if not better quality than the other brands!
ultimateone
Boston
23 BB Sas Carbon Gray
Curious that is says plug and play yet there seems to be a lot of extra wires as well.
St. Louis
What you are seeing is pigtail adapters to make it plug n play with the Bronco! Otherwise without these they would need extra wiring.
Headsong
I just wish I'd never seen this. Maybe a 4th of July sale.
Caleb
St Louis MO
âš  These headlights are BACK IN STOCK after months of backorders! âš
If you've been wanting a set of these, get yours while you can!
**PS** Hit the "Add to Quote" button on the product page, or message me for best pricing!
Ford Bronco IN STOCK: Form Lighting 2021-2024 Ford Bronco LED Projector Headlights 467853191_10227786721680199_2367490587926065877_n
Ford Bronco IN STOCK: Form Lighting 2021-2024 Ford Bronco LED Projector Headlights 467871849_10227786721640198_52452622635179494_n
NatureMan
United States
When will the rumored V2 be released?
