- Adam
- Aug 30, 2021
- 360
- 4,414
- 5,869
- Lindenhurst, NY
- Website
- www.4x4TruckLEDs.com
- 2018 Raptor & 2021 Bronco Outer Banks
- Outer Banks
We just received a nice shipment of MORRFlat Tire Inflation Systems. We have the Quad (125"), Quad+ (155") and Mega Quad (200") systems in stock!
The Quad system is perfect for the Broncos. We also have the extension hoses if you need one as well as the ViAIR adapters.
Inflate, Deflate, and Equalize air pressure in all 4 tires, all at once. See all of the uses below:
– Air up 1 to 4 tires simultaneously (Less stress on your compressor!)
– Air down 1 to 4 tires simultaneously (Less stress on you!)
– Check all of the tires’ PSI from the manifold (No more continuously bending over checking PSIs)
– Move air from a spare tire into other tires
– Effortlessly equalize tire pressures
– Make all 4 tires the same pressure
– Run different PSI in the front tires from the back tires
Grab your kit here: https://www.4x4truckleds.com/morrflate/
