- Mabett
- Dec 29, 2021
- 289
- 2,646
- 4,640
- China
- Website
- www.facebook.com
- Bronco Black Diamond
- Black Diamond
Looking for a way to make getting in and out of your SUV safer and more comfortable, while also adding a touch of style? Look no further than MABETT 2pcs Running Boards Side Steps.
Order now: https:www.amazon.com/promocode/A2R7KLNBDUEEAK, 30% OFF.
Note: Only fit 2-door/4-door Bronco with rock rails. It can't be installed without rock rails.
MABETT Running Boards Side Steps are an essential accessory designed to provide you with a better experience when getting in and out of your SUV, as well as loading and unloading cargo. Made of high-quality metal materials and coated with anti-slip rubber or other materials, these side steps ensure your safety and stability. Installing SUV Side Steps is easy and convenient, and they not only enhance your car's functionality but also improve its overall style.
Product Info
Features
Designed for easy installation, they come with protective padding that not only enhances slip resistance but also safeguards the original vehicle brackets.
Resistant to rust and corrosion, guaranteeing long-lasting performance and durability.
The side steps feature a non-slip surface treatment, ensuring secure footing.
Note: When installing the side step, pay attention to tighten the screws on both sides at the same time, so as to avoid that the holes cannot be aligned after one side is tightened.
Product Info
Brand | Mabett |
Material | Aluminum alloy |
Item Dimensions LxWxH | 22.83 x 11.22 x 4.33 inches |
Style | Modern |
Item Weight | 3.4 Kilograms |
Features
