Sold: Colorado KC Flex Era 3 dual mode SAE lights *Price Reduced*
5280Bronco
Denver
Selling my lightly used KC Flex Era 3 dual mode SAE fog light set. I had been using them on the front bumper and decided to go a different direction with shape. Paid $525 last fall.
https://www.kchilites.com/kc-flex-era-3-dual-mode-sae-master-pack-system-284.html
They have some minor chips on one lamp and for some reason the blue of the bezel varies between the two lamps, but the lights work great with no issues. Used for less than 20 hours. It has all of the original wiring harness that I modified, along with the harness I created for them to be hooked up to two aux switches (one for the fog and one for both fog and spot). Also included are yellow bezels and hard plastic covers shown in photo. As of 11/3 Looking for $250 shipped.
Ford Bronco KC Flex Era 3 dual mode SAE lights *Price Reduced* PXL_20230905_191116924
Ford Bronco KC Flex Era 3 dual mode SAE lights *Price Reduced* PXL_20230905_190557729~2
Ford Bronco KC Flex Era 3 dual mode SAE lights *Price Reduced* PXL_20230905_190604683
Ford Bronco KC Flex Era 3 dual mode SAE lights *Price Reduced* PXL_20230905_191101046
5280Bronco
5280Bronco
Denver
Price is now $325 shipped.
cpmartin1999
chris
Atlanta
2022 Badlands, 2020 VW Atlas
hello, are these still avail? also, you say you wired them to 2 AUX switched, i assume i would be able to do the same? I was wondering about that 2 position switch because i want to use the AUX switches in my badlands?
5280Bronco
5280Bronco
Denver
They are still available. I wired them to both aux 4 and 5 (I have another set of dedicated fog only lights wired to aux 6). When I switched on aux 5, I would get just the fog lights and then I could switch on aux 4 either at the same time as aux 5 or instead of aux 5 and it would turn on both the fog beams and the spot beams in combination. Does that answer your question?
cpmartin1999
chris
Atlanta
yes thanks, i apoligize as i checked them closer i want the ditch lights and they "say" these are for fog lights or bumper area.
5280Bronco
5280Bronco
Denver
Makes sense.
5280Bronco
5280Bronco
Denver
Do you have any pictures of them mounted on your Bronco?
Sorry! Lost track of time this week. Here are some that I could find quickly including some beam pictures with just the fog, fog and spot and then the fog and headlights together:
Ford Bronco KC Flex Era 3 dual mode SAE lights *Price Reduced* PXL_20230116_155538410~3
Ford Bronco KC Flex Era 3 dual mode SAE lights *Price Reduced* PXL_20230603_192824414~3
Ford Bronco KC Flex Era 3 dual mode SAE lights *Price Reduced* PXL_20230603_185032260~2
Ford Bronco KC Flex Era 3 dual mode SAE lights *Price Reduced* PXL_20230603_185009620~2
Ford Bronco KC Flex Era 3 dual mode SAE lights *Price Reduced* PXL_20230603_184930238~2
5280Bronco
5280Bronco
Denver
Price is now $250 shipped.
