jaruss01
NJ
Front Seats
-Inner elbow pad to inner elbow pad - 54.25”
-Outer elbow pad to outer elbow pad - 59.5”
-Upper door pad to upper door pad - 56.75”
-Glass to glass - 61”
-B Pillar to B pillar - 54.25” (better than we thought)
-Upper dash width - 54” (there is a 2”gap on either side between the door)
-Mirror to dash - 8”
-B pillar to center console - 24” each side
Rear
-Outer elbow pad - same as front. 54.25”. Basically all door to door dimensions are the same.
-Rear b pillar to b pillar - 53”. EDIT I think I messed this one up. It should be 51” since it the same face that continues into the upper cargo section which is 51”. Plus the bench is 48” so 51” sounds right
-Bench 48” (the rear seats look narrow because the sit in between the b pillar, there’s 3.5” of clearance between the seat cushion and the door on either side)
-With my seat comfortably back for 6-0” 32” length jeans - the rear seat had 10.5” of legroom from seat back to edge of seat cushion. And 28” overall to rear seatback
-My wife packs Fresh Direct bags filled with toys and loads the entire rear floor. The seating setup is optimal for this. The passenger seat back (in a lax position) to the rear hinge under the backseat is 18” at load floor. This is a big deal for me. As far as tucking stuff under the seats beyond the hinge I don’t see much usability here.
Cargo
-Seatback to rollbar (visibility) -11”
-Floor to seat back height - 25”
-Floor to beltline/tailgate top height - 21”
-I included the dimension of the rear tire above the tailgate. Chances are I’m stacking cargo up to the 25” mark given the seatback and tire situation. So 4” above the windowline
-The cargo door latch intrudes 3”
-everyone was waiting on this one - cargo depth from tailgate to seatback at top of tailgate - 34”
-Cargo sidewalls angle out some - 44.5” width at top, 43” at floor. Not including the wider cargo area towards the top which I think is 51”
-32” deep load floor to hump. 37” deep including hump
FYI some photos failed to load.
Ford Bronco Tape Measured Dimensions: 4-Door Bronco Front Seats, Rear, Cargo Area 6CE83E3A-D9E0-49B3-95DD-CDC4258E9A07
Ford Bronco Tape Measured Dimensions: 4-Door Bronco Front Seats, Rear, Cargo Area 9AE1EE46-C977-4EED-9CDE-9B7E1341B55D
Ford Bronco Tape Measured Dimensions: 4-Door Bronco Front Seats, Rear, Cargo Area 543C1446-E3E0-4150-BF8E-C45B94E9F1CC
Ford Bronco Tape Measured Dimensions: 4-Door Bronco Front Seats, Rear, Cargo Area 82AB5B87-2933-4AF8-8A07-10A25AF7060A
Ford Bronco Tape Measured Dimensions: 4-Door Bronco Front Seats, Rear, Cargo Area 0C33BCBE-A2F7-44F5-832D-D996D60968F6
Ford Bronco Tape Measured Dimensions: 4-Door Bronco Front Seats, Rear, Cargo Area 453C503F-E8AA-4885-B9C5-45FD02FBD3E3
Ford Bronco Tape Measured Dimensions: 4-Door Bronco Front Seats, Rear, Cargo Area 214B27E0-E872-4E65-B393-D9DB321DB322
Ford Bronco Tape Measured Dimensions: 4-Door Bronco Front Seats, Rear, Cargo Area 9BDCBFC9-20AC-4D98-9E98-3488D1EF5E73
Ford Bronco Tape Measured Dimensions: 4-Door Bronco Front Seats, Rear, Cargo Area 355E50C6-FBD6-4B3A-B92F-5ADB0B14A58B
Ford Bronco Tape Measured Dimensions: 4-Door Bronco Front Seats, Rear, Cargo Area AB9BBD98-1F49-428E-8317-9E832AA242FE
Ford Bronco Tape Measured Dimensions: 4-Door Bronco Front Seats, Rear, Cargo Area 71DDE369-BBB0-41FE-87E7-9EBFC25B71A7
Ford Bronco Tape Measured Dimensions: 4-Door Bronco Front Seats, Rear, Cargo Area A660E84A-F4C7-4E4C-9719-91E9AC6A3361
Ford Bronco Tape Measured Dimensions: 4-Door Bronco Front Seats, Rear, Cargo Area D403CAA5-3B22-4BB5-B12D-2FC678CCEE67
Ford Bronco Tape Measured Dimensions: 4-Door Bronco Front Seats, Rear, Cargo Area E814DE98-D27C-476E-ADB7-9F7456CF0B08
Ford Bronco Tape Measured Dimensions: 4-Door Bronco Front Seats, Rear, Cargo Area 54B4D122-83C4-4DAF-8B45-67580B23C27F
Ford Bronco Tape Measured Dimensions: 4-Door Bronco Front Seats, Rear, Cargo Area 977E02D1-AECA-4828-8A62-A6638B854EB0
Ford Bronco Tape Measured Dimensions: 4-Door Bronco Front Seats, Rear, Cargo Area 9A317D73-DB66-41A5-B97F-16743B2CC045
Ford Bronco Tape Measured Dimensions: 4-Door Bronco Front Seats, Rear, Cargo Area E1C1D093-196A-42CD-AA63-BF2E4340D21F
Ford Bronco Tape Measured Dimensions: 4-Door Bronco Front Seats, Rear, Cargo Area 62C70DF7-0BC9-4714-B92D-330AFBB12827
Ford Bronco Tape Measured Dimensions: 4-Door Bronco Front Seats, Rear, Cargo Area 52284CE6-843A-4D6D-9CD5-11F606ADEBC6
Ford Bronco Tape Measured Dimensions: 4-Door Bronco Front Seats, Rear, Cargo Area 6525A33E-9F9D-4F67-AACA-C7B5FCE1CFAF
Ford Bronco Tape Measured Dimensions: 4-Door Bronco Front Seats, Rear, Cargo Area F28D9E9A-54DD-4AF8-96FD-E80FC4E41431
Wanted33
Down south in Dixie
Just one more measurement, and I wouldn't have to take my trusty Stanley tape measure with me to the viewing. :) That's the distance between the cargo floor, and the underside of the cross member of the roll bar. However, thank you for the others. Those will give me more time to look at other things on the Bronco.
BTW, did ya say "hey" to Tom? @DealerInsider :cool:
Wanted33
Down south in Dixie
Tom is at Chapman Horsham. This event was at Chapman Philly. That's why I didn't go.
Quite a big dealership I take it. Like Hendrick's in my area. You can't swing a dead 'possum without hitting a Hendrick's dealership. :)
Garemlin
Delaware
There are seven between PA and NJ. Five of them carry Ford.
Elmosaurus
Elton
Harveys Lake, PA
‘23 Bronco 2dr BL & ‘22 Ranger SCrew Lariat Tremor
They are sister dealerships. Should have gone, we had a great time. Met a few other B6G members there too. :)
lakesinai
Charleston SC
Front Seats
Rear
Cargo
Nice work! I saw my first Bronco yesterday in Charleston SC, I'm 6'5", and fit very comfortably in the drivers seat. The electric seat (only available with the leather) makes alot of difference in adjustability.
jaruss01
jaruss01
NJ
A couple things I thought about between the BL and OBX sas - 1. The manual seat controls drove me crazy in person. Are they any different from other manual seats? Probably not, but its been awhile since I had a vehicle with manual seats. 2. The rear legroom is adequate, but not great. the molle grid steals a valuable 1". And with a rear facing baby seat, maybe that becomes 2" in instances where you want to recline the passenger seat during a road trip with a rear facing baby seat behind you.
kencantrell
Ken
Atlanta GA, USA (ATL)
Toyota Camry SE V6; Ford F250 crew cab
Great info! Compared your measurements to my current DD: 2012 Camry SEV6 (stealth hot rod; same 0-60 as the original Acura NSX, but I digress...). Very similar in most front and rear seat horizontal dimensions. Bronco slightly bigger in general, with of course much more headroom. Inside is not huge, but at 5-11, 175 I have plenty of room in the Camry so will have plenty in the Bronco. Can’t wait to pass on the Camry and hit the trails in the Bronco.
Pennington
Lorne
Ontario
2009 Escape
I need the same measurement. Fingers crossed the dog fits.
jaruss01
jaruss01
NJ
We have it. 25” load floor to seatback plus 11” seatback to underside of roll bar.
So 36” to load floor. But hump is 3” tall so if you want the dimension from the folded seats to roll bars it’s 33”. Maybe 32.5”. I think the hump is between 3-3.5”
jaruss01
jaruss01
NJ
is it really 52” to the hood? How am I only seeing this for the first time?
Hell yeah it is. That number stuck with me. That was the one photo that I reserved for flex status and told myself don’t forget to tell your friends...52” tall front lol
