- John
- Jun 16, 2021
- 35
- 480
- 926
- New Castle, Delaware
- F-250
- Badlands
Hey Bronco Team!
We are super pumped to bring you a cast aluminum transmission pan for your 2021+ Ford Bronco with 10R60 transmission. This cast aluminum transmission pan replaces your stock plastic one (known to warp and crack over time). It increases fluid capacity by 2 quarts and has a magnetic drain plug to prevent metallic debris from floating through your transmission. The dovetail-style groove with o-ring seal prevents you from having to mess with an o-ring with a mind of it's own.
One of my favorite features of this pan is the orange bolt-retainer setup. It's really big pain installing transmission pans by yourself. Getting those first few bolts started while holding the pan (or using 2x4's) is not easy. The bolt-retainers help hold that hardware in place so they aren't falling on the floor behind your head.
What is your favorite transmission fluid to run?
- John
- John
