- Beefcake
- Dec 30, 2021
- 125
- 282
- 111
- Cincinnati
- 2021 Bronco
- Big Bend
Check out the NEW Steeda adjustable rear track bar for the 21+ Bronco!
Prevent unwanted lateral movement during articulation and flex with this adjustable rear track bar. Compatible with Bronco's at stock ride height up to a 7-inch lift, this adjustable bar will keep your Bronco driving right. Depending on the trim level of your Bronco, they come with different ride heights. Yet they all have the same track bar (excluding the Raptor). On some models, we have seen the rear ends 3/8” off-center, possibly up to 1/2”. This Steeda track bar fixes that issue.
Maintain good handling. When you lift your Bronco, the stock track bar can pull the rear axle off-center. This leads to poor handling and driveability issues. With this adjustable track bar, you can push or pull the rear axle back to the center.
Easy adjustment. Adjustment is easy with this rear track bar. Unlike other bars on the market, you do not need to unbolt the track bar to adjust it. The two-way adjuster in the bar allows you to quickly and easily adjust the panhard bar with a set of wrenches.
Product Benefits:
Product Benefits:
- Adds no NVH
- Made in Valdosta, GA
- Compatible with a 7-inch lift
- Corrects the rear axle position
- CNC bent thick wall 1-3/8 inch DOM steel tubing
- High strength billet steel, zinc plated bushing sleeves
- Billet 4140 chromoly steel, nickel plated, heat treated double adjuster
