RealTruck
Lux Sponsor (Level 2)
Ocala, FL
N/A
Wanted to share these because one feature that really stands out is the adjustable step height.
The new RealTruck Traxio Nerf Bars feature the RightHeight™ Bracket System, which lets you adjust how high or low the steps sit. Whether your truck is stock, leveled or lifted, you can dial in the step height that works best for your setup instead of being stuck with one fixed mounting position.
Ford Bronco New Traxio HEIGHT ADJUSTABLE Nerf Bars! 480354-a9044fb5dc8327783f402f2eb869c79d
A few other highlights:
🔴 Up to 600 lbs. capacity per side
🔴 Large anti-slip step pads for plenty of footing
🔴 Molded end caps to help protect against rocks and road debris
🔴 Available in polished stainless or black powder-coated steel
🔴 No-drill installation using factory mounting points
🔴 Installs in under an hour for most applications
🔴 Available in 3", 4" and 5" widths
The Traxio lineup also comes in at a really competitive price point, especially considering the adjustability and different size/finish options.
Ford Bronco New Traxio HEIGHT ADJUSTABLE Nerf Bars! 480355-7202ecfd43f017662c039d70e2b81cb9
👉 Check out the Traxio lineup here!
DM me or email me at [email protected] to get set up with exclusive forum promotions, shipping times, and to make sure your steps are a perfect fit!
RealTruck
RealTruck
Ocala, FL
N/A
Valhalla
Valhalla
Chattanooga Tn
So that is how it works, I see....
RealTruck
RealTruck
Ocala, FL
N/A
There are 3 mounting points for you to adjust height. 1 Inch down from the rocker panel, 2 inches down and 3 inches down.
Valhalla
Valhalla
Chattanooga Tn
It's been nerfed...
RealTruck
RealTruck
Ocala, FL
N/A
Valhalla
Valhalla
Chattanooga Tn
I don't trust it in a hit...
