Now AVAILABLE here at Lethal Performance! Anderson Composite Carbon Fiber Fender Flare Delete Kit!!
lethaljake
Jake
West Palm Beach, FL
2022 F-150 RCSB 5.0
Hey, ALL!
Now available from us here at Lethal Performance is the Anderson Composite Carbon Fiber Fender Flare Delete kit for 2021-2023 Ford Bronco 2-DR & 4-DR!
Couple of featured highlights:
*Flare Deletes replace OE fender flares (set of 4-front & rear)
*Fits 2-door Bronco
*Does not fit Bronco Everglade or Bronco Raptor
*Maximize tire clearance, increases distance to off-road obstacles
*Vacuum infused process with 3K, 2x2 twill carbon fiber cloth, gloss finish
*Mounts with stainless steel hardware (included)
*May require modifications for correct fitment. Minor adjustments may be necessary as part of the normal installation process.
*Hand crafted; approximate weight 4.3 lbs. per set of 4
*Shipped via ground truck freight only
*Anderson Composites is a supplier of carbon fiber products for Ford Performance Parts.
Check it out here ---> Anderson Composite Carbon Fiber Fender Flare Delete Kit - Front & Rear (2021-2023 Ford Bronco 2-Door)
** 4 DOOR is set to be available Summer of 2023
Ford Bronco Now AVAILABLE here at Lethal Performance! Anderson Composite Carbon Fiber Fender Flare Delete Kit!! anderson bronco
Of course, if you guys have any questions; feel free to reach out to any one of us here at Lethal Performance and we'll be more than happy to assist!
