Opinions wanted between these two wheels - Vision vs Method
Dyehard
Dyehard
76' Ford Bronco
Ha Ha! Thank you all very much but I may just be more confused now!
1975U15
2019 F-350 SD, 1975 Bronco
Do you have an issue with rocks hitting the sides of your Bronco?
Not yet. But do get significant spray on wet roads due to tire beyond flare.
Last weekend I did the DIY universal mud flaps up front to hopefully knock down rocks thrown from middle of tread.
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
Having a hard time choosing between these two wheels. Anybody have an opinion on either they would care to share?
I like the top wheel. And it also looks easy to clean. I have made that mistake it the past with wheels that are hard to clean
MaverickMan
Shane
Outlaw IIs
malt_liqueur
Portland
Tacoma
probably the Methods. The way the Venom wheels have the small bump out for their branding bothers me
Raptor911
Raptor911
Broadlands, VA
Some advice .. don't buy either. I am not sure why BUT at some point wheel manufacturers starting using fake bead-lock rings with bolts (and on the outer most part of the wheel). This simply just add unnecessary weight to the wheel just for looks.
Remove all the bolts from the 4 method wheels and you have 96 bolts.
