Can’t seem to find anything that will help. Has anyone wired their Oracle grill letters to their DRL’s? I don’t have upfitter switches.
Thanks!
Thanks!
I used this harness .Can’t seem to find anything that will help. Has anyone wired their Oracle grill letters to their DRL’s? I don’t have upfitter switches.
Thanks!
Bronco headlight plug connector-2022-2023-with Led Headlights | eBay
The harness that Rydfree posted a link to is the same as StarKey's harness. On the Starkey's site is a YT video showing hookup and the functionality it provides.Will this make them only come on with the headlights only? Or headlights and running lights?
They will come on anytime the marker lights are on . I leave my headlight switch on Auto so they are off during the day . You can make them come on by turning the switch to manual operation if you want. I also run mine thru a relay via one of my overhead aux switches that will override them and keep them off even if the headlights are on.Will this make them only come on with the headlights only? Or headlights and running lights?
With the black wire grounded, you can connect to aux switches, parking lights, or use an "add-a-circuit" to add to any power source you choose, which could include ignition switched fuses in the fuse box.Can’t seem to find anything that will help. Has anyone wired their Oracle grill letters to their DRL’s? I don’t have upfitter switches.
Thanks!
