- Josh
- Apr 25, 2022
- 376
- 533
- 179
- Salem Ohio
- 2022 Bronco 4-door
- Badlands
ORACLE Lighting - Universal Illuminated LED Letter Badges - Fits 2021-2023 Ford Bronco
Price: $34.88 USD onwards per letter
Discount code: AN5
Link to Buy: https://ticklemybronco.com/search?q...ter Badges - Matte White&options[prefix]=last
Customize your vehicle with a vibrant new look with universal LED letter badges from ORACLE Lighting! These individual LED illuminated letters for cars are the perfect way to make your own marquee-style glowing vehicle badge. When turned on, the letters emit a soft edge-lit glow to make your custom badge stand out. Even when off, the sleek design of the letter housings gives a customized high-end appearance. The premium construction and overall styling deliver great value for an easy DIY illuminated badge. Simply choose the letters you need, and get ready to draw attention to your ride with a build-your-own glowing letter design!
The LED lighting has a low draw, less than 0.1 Amp per letter. The overall size is approximately 3.75" wide x 1.4" tall and 0.5" thick. Installation is easy with the VHB double-stick adhesive. Wire the letters to a 12V source such as parking lights, ignition fuse, or a separate toggle switch. Please note that a hole may be required to route the wire, and each vehicle’s needs will be different. We recommend using our VHB Primer (ORACLE Part# 2082-504) to get the best bond with the mounting surface. Available in Matte White or Matte Black Surface Finish.
Fitment: 2021, 2022, 2023 Ford Bronco
Discount code: AN5
