Possible bad reception fix
DamianCJK
Damian
Ontario
Since early fall I noticed crappy radio reception with my 21 Bronco. I did have a stubby antenna on but it worked fine in spring when I had put it on. I switched back to the factory for the winter and no change. I thought ok maybe my antenna wire came loose as that was how my radio on FM sounded barely getting any type of reception. I bought a 13 inch antenna to try again before I rip my bronco apart to see if there was any difference and there was none. Today I played with Forscan and went into the APIM Modual Configuration searched up theme, selected QT HMI theme and changed classic to Smart surface and once I did the power off and on did a reset on the radio and all worked perfectly again. Not sure if this works for anyone else but worked for mine.
