- Josh
- Apr 25, 2022
- 376
- 533
- 179
- Salem Ohio
- 2022 Bronco 4-door
- Badlands
Rough Country 40300 Fits 2021-2022 Ford Bronco 1in Leveling Kit in Stock at TMB!
The Ford Bronco is back and better than ever! Rough Country has hit the ground running to give your 2021-up Ford Bronco an improved, aggressive stance with a 1-inch leveling kit! This easy-to-install kit levels your vehicle from front to rear, giving you increased ground clearance to run larger tires while eliminating the nose-down factory look for a commanding presence.
When it comes to leveling your Bronco, a small lift can make a huge difference! By lifting the vehicle's front end to match the height of the rear, you get an instant transformation that won't sacrifice the factory ride quality.
Each kit features upper and lower steel strut spacers, laser-cut for a precise fit, and powder-coated black to resist the elements. Rough Country's 1-inch Leveling Kit features an easy, 100% bolt-on installation process with no need for complicated strut disassembly. Includes a Lifetime Replacement Guarantee!
FEATURES
FEATURES
- Levels the front with the rear of the vehicle
- Easy bolt-on installation
- Maintains factory ride quality
- Increased ground clearance
- No need to disassemble your struts to install
- Does NOT fit Bronco Sport models
- Will fit Sasquatch edition
- Will fit Badlands edition
