Maryland Rough Country Speedometer Calibrator
Tomfordgt
Tom
Maryland & Delaware
Ford F450
Selling a new, unused Rough Country speedometer calibrator. part number 90015. https://www.roughcountry.com/speedometer-calibrator-90015.html
Cost $259, asking $150 shipped in the CONUSA.
  • Resets your speedometer to accurate readings for larger tires
  • Easy Plug and Play connection
  • Updates OE ECM Shift Points to accommodate larger tires
  • Recalibrates Electronic Stability Control to work with larger tires
  • Option to return to stock settings
  • 1-year warranty
    Ford Bronco Rough Country Speedometer Calibrator IMG_5630
    Ford Bronco Rough Country Speedometer Calibrator IMG_5628
    Ford Bronco Rough Country Speedometer Calibrator IMG_5629
jbacchi70
Joe
Jeep GC, 1968 Plymouth Road Runner
Does this connect directly to the ODBII connector?
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Do you just need to use this once and you’re all set - or do you need to keep it plugged in?
I just adjusted via Forscan - but, is this essentially doing the same thing?
Tomfordgt
Tomfordgt
Tom
Maryland & Delaware
Ford F450
The directions are on the website: https://www.roughcountry.com/speedometer-calibrator-90015.html
No, there's a little more to it but its simple, from the rough country website:
"This plug and play device connects directly to your vehicle’s Diagnostic Link Connector Port and in just a few short minutes your speedometer reads true again! Rough Country’s Speedometer Calibration Devices don’t just simply change your in-dash readout, they update your vehicle’s ECM, ensuring accurate shift points and proper electronic stability control."
Tomfordgt
Tomfordgt
Tom
Maryland & Delaware
Ford F450
It stays plugged in behind a center console panel. As far as changing the speedometer it does the same thing. I don't think that forscan changes your shifting points (on a auto) or recalibrates the ESC for larger tires.
redone17
Cold Spring, NY
Huh…I wonder about the ESC - didn’t think about that. Manual transmission - but, that didn’t cross my mind.
But this says 2016-2020 Ford?
Tomfordgt
Tomfordgt
Tom
Maryland & Delaware
Ford F450
redone17
Cold Spring, NY
PM’d
