Slipstream Accessories
Diabolical Inc
Lux Sponsor (Level 2)
shop.diabolicalinc.com
2020 Rubicon, 2021 Bronco Wildtrak
Now that many of you have seen the product, lets take a look at some of the accessories that re available for it. Although the images are of a Jeep, the actual products are the same as the Folding top dimensions are the same.
The Molle Panels: Besides the obvious function of securing bags, medical kits, ect, we all know that Molle Panels give you the ability to organize your storage in a secure spot. The also provide structural support and beef up the folding top so it can carry heavier loads. Without the Molle Panels you can carry about 150 Lbs on top of the Slipstream. With them, you can load about 190 Lbs. as the panels themselves distribute load over a greater area.
Ford Bronco Slipstream Accessories Molle JLU
Ford Bronco Slipstream Accessories mollepanel001
Forward Wall Molle Panel: Besides the obvious function of securing bags, medical kits, ect, we all know that Molle Panels give you the ability to organize your storage in a secure spot.
Ford Bronco Slipstream Accessories 1663014027042
The Rail Rack: This simple rack platform bolts into the tie-down rails to give you a mounting platform for any accessory you like. We designed this for Hi-Lift Jacks, to keep them out of the elements, but others have used them for power tanks, rifle mounts, ARB Compressors, or anything you wish to mount. It comes in a 4.5" and 7.5" wide platform.
Ford Bronco Slipstream Accessories Rail Rack with jack2
Ford Bronco Slipstream Accessories Rail Rack with Powertank 2jpg
Marine Deck Foam Pads: For those of you that know Marine products, you know how these stand up to the elements. We searched for a foam pad that would stand up to everything, and the Marine Deck Foam was the only way to go. These pads are made to be in the elements 24/7. On a 105 Degree day, these are still cool to the touch. They will withstand everything that you can throw at them.. They will keep you cargo in place while tied down to the Tie-Down rails. They will protect the slipstream from scratches on the top.
As these are just a few of the Accessories, there are plenty more to come.
Ford Bronco Slipstream Accessories idrive turkeyday
tlianza
Tom
Marin County, CA
lianza.org
2022 LUX/2.7/A51/OBX
How do the Marine Foam pads attach to the Slipstream? Magnets? Adhesive?
