- Adam
- Aug 30, 2021
- 355
- 4,381
- 5,844
- Lindenhurst, NY
- Website
- www.4x4TruckLEDs.com
- 2018 Raptor & 2021 Bronco Outer Banks
- Outer Banks
If you're looking for a way to easily and quickly air down your tires then the Staun Tire Deflators are THE go to tire deflation system. They easily screw onto your tires and deflate them to a pre-set PSI (which you can set). I've personally been running the same set on my trucks for about 17 years now. They work rock solid.
We recently picked up the brand since we've had a lot of local folks asking us where to buy them (we have a big beach fishing community here)
The most popular ones are the Standard Duty as they are adjustable from 6-30PSI which covers the range almost every off-roader needs. But we also stock the Light Duty and Heavy Duty if you have a different application in mind.
Light Duty, 0-10 PSI: https://www.4x4truckleds.com/staun-tire-deflator-4-pack-light-duty-0-10-psi/
Standard Duty, 6-30 PSI: https://www.4x4truckleds.com/staun-tire-deflator-4-pack-standard-duty-6-30-psi/
Heavy Duty, 15-55 PSI: https://www.4x4truckleds.com/staun-tire-deflator-4-pack-heavy-duty-15-55-psi/
The tyre deflators are simply screwed onto each tyre valve stem doing all of the work for you! All you have to do is take them off your tyres when they stop deflating and you’re set to go off-road!
The Staun Tyre Deflators can be used for all types of four wheel driving ranging from coastal sand driving, desert sand driving and rock climbing to mud driving. The tyre deflators are supplied at a preset pressure of 18psi, but this pressure can be adjusted to your desired level.
FEATURES
- They are fully adjustable
- Each deflator has an adjustment range specific to the level of deflation you require
- They are easy to use, not requiring any tools
- They are highly accurate, deflating to within 0.25psi of the preset pressure they have been adjusted to
- They are the smallest tyre deflators available measuring only 30mm x 15mm (1.18” x 0.6”)
- They are one of the lightest deflators weighing only 32 grams (1.13 ounces)
- They are made of 100% brass
- They are the fastest deflators on the market (tests found a normal 10rx15 tyre takes approx. 1 minute and 30 seconds to deflate from 32psi to 18psi)
- Every deflator is completely pre-tested to ensure high performance
- They are covered with a 2 year guarantee
- They can be used for all types of four wheel driving ranging from coastal sand driving, desert sand driving, rock climbing to mud driving.
With an adjustment range of 30psi down to 6psi, the tyre deflators are fully adjustable and are the smallest tyre deflators available measuring only 30mm x 15mm (1.18” x 0.6”). They are also one of the lightest tyre deflators weighing only 32 grams (1.13 ounces), made of 100% brass. Every tyre deflator is completely pre-tested to ensure high performance and are covered with a 2 year guarantee.
The Staun tyre Deflators can be used for all types of four wheel driving ranging from coastal sand driving, desert sand driving and rock climbing to mud driving. The tyre deflators are supplied at a preset pressure of 18psi, but this pressure can be adjusted to your desired level. How much you reduce your tyre pressure depends on a variety of factors, such as how much weight your tyres are supporting, or the softness of the surface that you will be travelling on.
