Tricky Dick's Dirty Bronco
Status
Not open for further replies.
MrGreen55
Kyle
Oregon
toyota scion xb
Crossed the 3k mark today, rolling at 12 psi after a day at the dunes. Baja mode is a riot.
Would a 5ft flag be better if you run a led whip if mount in the same spot?
Tricky Dick
Dick
PNW
www.TD-Distributing.com
IDK about better, but it should well. I was right at 8ft with the 4ft whip and a little more doesn't hurt.
Roll Sound
Hollywood
2021 Wildtrack 2DR MIC OW, 2014 KTM RC8R
Hey, what ever became of your cracked steering wheel airbag cover? Any resolution?
  • Like
Reactions: Cat
Tricky Dick
Dick
PNW
I'm waiting for it to get worse, and it is slowly.
Fonz54
Lou
Monterey, CA
Jeep Commander, Porsche Cayenne, Mercedes C250
Back from my journey. Nearly 1000 miles all said and done. Had a blast. Averaged a tick over 17 mpg even with about 8 hours of offroading mixed in.
Drug home a twill Bestop and a Ranger aluminum spare. It's 16x6.5 +55, for $20 I could see it being useful.
Which D-Rings did you buy and from where? Pretty close to Dozer Yellow.
Tricky Dick
Dick
PNW
Ambull from Amazon. Very good match to my interior accents.
Fonz54
Lou
Monterey, CA
Tricky Dick
Dick
PNW
Let's see, stuff happening.
Debaged the exterior except the blue oval.
Finally sold my stock wheels/tires.
Contacted Grainger and canceled my ESP. I decided I want to void the warranty so much that it won't be worth having.
And then I dove into Forscan. Lowered the TPMS to 32, enabled global close, and double click panic. Let's see what else I can find.
Tricky Dick
Dick
PNW
And now Sport mode is added. It doesn't feel any different though, probably because I've been in full control of my shift points all along.
And for my records if I want to revert back, it was a 9 that I changed to B.
Tricky Dick
Dick
PNW
I put the soft top on today. I may never go back, it was a pain.
Found out that any old 315mhz seem to keep the TPMS light off, even if they don't read accurately. I put these F150 wheels on a few days ago and still no light. I pulled off the Motegis to get proper sensors in them since the ebay ones I tried were also on/off.
Turns out those wheels didn't even have sensors at all! I broke a bead on one to check and nada. Since I sold my stock wheels and I want to get some semblance of good mileage on my trip, I'm putting a nice set of 285/70/17 Pathfinder SATs I had from a previous truck onto these wheels (those Coopers pictured are weather checked, bald, and E range, do not want!). Tire Rack TPMS sensors are on the way, learned my lesson with the ebay sensors.
Installed my brake controller today.
Ford Bronco Tricky Dick's Dirty Bronco PXL_20220511_014509051
Cat
Cat
Whidbey Island, WA
MB500SL, HD Road King Custom
Your Bronco is one sweet looking ride, @Tricky Dick !
Nicely done.
Tricky Dick
Dick
PNW
Packing up to wheel with a CO 4dr tomorrow in northern Idaho. Forgot one little thing and thought the bungees would give enough to slip it in. Nope, ripped the handle right off, she's broke.
Ford Bronco Tricky Dick's Dirty Bronco PXL_20220515_011858842
Tricky Dick
Dick
PNW
Ran Compressor Trail today. Had a great time til on the way back I sucked up a boulder and wrecked my shit. Limped home and I have 4 weeks to get everything fixed.
Ford Bronco Tricky Dick's Dirty Bronco PXL_20220515_192425234
Ford Bronco Tricky Dick's Dirty Bronco PXL_20220515_203607503
Status
