redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Sounds like you want to control one of the legs after the NOCO power entry which is a much harder task. Nothing off the shelf I'm aware of for this particular use case.
This looks ruggedized similar to what you're describing, but is going to lose power once the NOCO is disconnected, as are all of the inline 120V wireless relays meaning they'll need to reconnect to wifi when plugged back in. Same for the Kasa plug I mentioned if you put it in the engine bay.
For this use case you've described, need a 12V powered relay that receives power from the Bronco and both receives wireless commands and passes 120V through.
Yeah, hence the manual waterproof inline switch…which isn’t the end of the world.
Chrome_Pony
Chrome
The Great Land
It is the simple way for sure.
Rather than leave some switching equipment on the Bronco, I've considered playing with an SAE J1772 EV plug and putting the 120V (heaters) on the AC legs and 12V (tender) on the control legs.
Ford Bronco 2021+ Bronco ForScan Thread 1696383012990
rblock50
Ryan
Orange County, California
VW, Bronco
Check #13 on the spreadsheet:
Also this thread might be helpful:
https://www.bronco6g.com/forum/threads/rear-12-volt-port-timout.29712/
Personally I wouldn't bother reprogramming, I would simply trace the wire back up to where it gets power (probably under the hood somewhere) and re-route it directly to the battery. If you wanted to be fancy, use a three position switch inline so you could choose whether you wanted to power it straight from the battery for peace of mind when towing, or powered by the circuit so it will have a timeout for battery protection when you're not towing. Just run the original wire to one pole of the switch and the battery wire to the other, then connect the wire going to the power point to the center. Flip it one way and you're on battery power, flip it the other and you're back to OEM operation, make sure you label it correctly LOL
LOL, now I know what that Row #13 was for. I read it as "Power Point", and kept wondering why my Bronco cares about my Power Point presentations. Mystery solved!
Groundhog
Ozark
'22 Wildtrak, '21 OBX
Does anyone know if it is possible to change the speed at which the auto high beams come on? It seems like it is set to 32mph by default, but the speed limits around where I live are only 25mph and it is pitch black at night with millions of deer running around, so I'd like my auto high beams to come on at lower speeds if possible. Thanks in advance for any guidance on this.
Has anyone been able to change the auto high beam speed? Seems absurd they are disabled at 30mph.
GomezK6
Wilmington, NC
2022 Badlands, 04' Subaru WRX STI
I know this isnt necessarily a FORscan topic but it kinda goes into it. I am using a VCX NANO I can connect to FORscan but I cannot connect to FDRS. FDRS does not allow me to select "different device" option. I was told to call FORscan or contact them in order to get the drivers specifically for the VCX NANO but that doesn't sound right either. Does anyone have any experience using the VCX NANO and FDRS or can help me figure out how to get this thing connected.
mpeugeot
No you should call Ford for support. FDRS is a Ford Motorcraft Software Product... FDRS has been working fine with VXDIAG VCX Nano in the past.
My next suggestion would be to fully uninstall and reinstall FDRS, since you initially installed it without the VXDIAG VCX drivers missing.
GomezK6
Wilmington, NC
Apologies I meant to say I did call Ford for FDRS support and they were the ones that told me to call/contact FORscan.
BigMeatsBronco
Allan
2021 FE 2 door
last statement shows the FAKE....he's fake. there's no way in he'll anyone at FDRS told him to call or contact the folks at forescan...
redone17
Cold Spring, NY
I can’t figure out why I’m still getting the “use parking brake” doo-dee-doo every time I start up.
mpeugeot
Ford Bronco 2021+ Bronco ForScan Thread Screenshot_20231107_213817_Chrome
Turns out that he's just unlucky... So there's that. I must admit, it was strange how it all went down.
Lawman
Joliet, IL
2023 Bronco Wildtrak 2 Door
I want to add 4 blinks to my lane change signal... However, I have different default values than what's listed in the spreadsheet. I don't have either of the 2 default values (didn't modify anything)
Do I just test to see what I get?
Did you ever get an answer for this? I have the same values as you and want to change to 5 blinks!
TheGOAT
Mo
Qatar
Bronco Raptor
Okay guys, has anyone figured out how to show the forward tire tracks path when using the front camera with the vehicle in Normal mode? Please dont suggest Baja or rock crawl mode, neither are a good alternative.
Sighlense
Upstate NY
2015 Mustang GT - 2022 Bronco Wildtrak
What page has a link to the latest (working) forescan link?
35tires
'23 Bronco, '21 4Runner
Do I need forscan to stop the dinging from coming through my speakers when I get in and out of the car or start it? It is SO loud on my stereo it's driving me bonkers.
Any idea?
Rob_Broncowski
MA
'22 OBX, Ducati Scrambler
Any idea?
Yes. Turning off all the chimes is one of the best mods you can make with Forscan.
