2022 Black Diamond heater trouble .
Alaska
Ford Bronco
Hi everyone , I’ve noticed the heater floor vents on my ‘22 Black Diamond put out very little heat . The defrost and vent settings work just fine . Is this normal for these things ?
DUSTYcazOREGON
Craig
2021 Ranger Tremor/2022 Bronco/2006 Dodge Charger
I would say yes. Mine is the same and there is the same issue on the Ranger truck. Look in your computer settings...there may be an adjustment in there instead of just dash buttons.
There's a bajillion page thread about this very thing here somewhere. Ford says it's working as intended.
Best you can do is turn on both floor and dash vents, then manually close the dash vents. That forces all the air to the floor.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there! If you send over a DM with your VIN and Ford dealer info, I can look into your concerns on my end.
