Biggest tires I can use without a lift?
DMC
SoCal
63 Superhawk
I have a ‘22 Big Bend and need new tires. I’d like to go bigger but don’t want to lift it. I do some off roading and lots of skiing but don’t really want off road tires. Suggestions? Photos? Thanks in advance!
Reidt131
Reid
Howell, MI
2019 F150,
If you are sticking with those stock 17" wheels there are a few options.
For the super safe option that has 100% no rubbing with crash bars installed, 285/70r17 will be a good bet.
For an option with a bit larger size but slight rubbing at full lock, 285/75r17. This also keeps crash bars
If you remove the crash bars I believe that you can go all the way up to 35x11.5r17 with minimal rubbing (others please correct if I'm wrong)
I plan to do the second option in a few weeks, just need to find a good deal on Toyos in that size.
That matches my understanding:
33's with the crash bars, 35's without. A lot depends on your tire width / rim offset / etc. though so I wouldn't guarantee no rubbing.
Reidt131
Reid
Howell, MI
2019 F150,
True wheel width and offset will effect clearance.
My thought is that the BB wheels are the same offset and width as the Badlands wheels, which ship stock with 285/70s.
lakesinai
Charleston SC
The Big Bend has 17x7.5 in wheels. The non-sas Badlands is a tad wider at 17x8, allowing a slightly wider tire.
lakesinai
Charleston SC
What I did I recommend. Badlands 17x8 non-sas OEM wheels with a very quiet, sure footed road and beach tire: Nitto Nomad Grappler 285/70R17 tires. Your BB wheels are 17x7.5. These tires add 2" width, .7" height.
DMC
DMC
SoCal
63 Superhawk
Thanks for the great info.
Thanks for the great info. I’m ok look at it all. I’m not clear on the crash bars though. Where are they?
Ford Bronco Biggest tires I can use without a lift? Screenshot_20240512-095155~2
Ford Bronco Biggest tires I can use without a lift? Screenshot_20240512-095205~2
Ford Bronco Biggest tires I can use without a lift? Screenshot_20240512-095233~2
I did some research on crash bars and looked at my truck and it seems that when we added the steel bumpers the front crash bars were removed(I can see the rear one). So do you think I can go bigger that the 33’s?
Ford Bronco Biggest tires I can use without a lift? IMG_3153
Ford Bronco Biggest tires I can use without a lift? IMG_3155
Ford Bronco Biggest tires I can use without a lift? IMG_3154
Reidt131
Reid
Howell, MI
2019 F150,
I am not sure if the two crash bars are different distances from the center of the wheel or if they are placed in about the same spot front to back.
If the rear crash bar is further away than the front one you would theoretically have more clearance.
I'll check tomorrow and let you know.
Discount Tire
Arizona, USA
discountti.re
All Things FORD
Thanks for all the great input. It was really helpful! I chose the Toyo 285/70/17 and I’m really pleased. No rubbing, looks great.
Ford Bronco Biggest tires I can use without a lift? IMG_3167
Like night and day. Mild to rugged wild. Great choice of tire size, it looks very proportional and not overwhelming on the Bronco. :clap:
  • Like
Reactions: DMC
Mike leggiero
Ky
35in on both with no lift and the green one just got lifted
Ford Bronco Biggest tires I can use without a lift? 1000000605
Ford Bronco Biggest tires I can use without a lift? 1000000658
Ford Bronco Biggest tires I can use without a lift? 1000000661
DMC
DMC
SoCal
63 Superhawk
Straight from Discount Tire. Shopped around and it was the best deal. Great company!
bdtyrrell
Bruce
New Jersey
How is the road noise with the new tires? Louder or quieter than the originals?
Mike leggiero
Ky
Maxxis
Maxxis razr at 35 12.50 17 they are quite got about 2000 miles on them
