Cell signal booster or GMRS radios
New Mexico
22 Wildtrax 4 door
What are people doing for overlanding communications? I'm up in the air as to how to proceed and am actually thinking about having both.
604Bronco
British Columbia
www.bronco6g.com
I carry a tin can tied to a reeeeeeeeeally long string, attached to another tin can.
Nothing is more reliable… Nothing!
MileHighCitizen
Al
Denver
Bronco 2D 2.7
A satellite messenger is your best bet. I received one as a gift and bring it off grid as a last resort if I’m going somewhere desolate. There is a fee, but you only have to pay for a month at a time when you’re going to use it. It’s a relatively cheap insurance to have.
The one I have is a Spot X, but there are many others.
GMRS also requires a license from the FCC to transmit anything over 2w, it’s only $35 for 10 years. I got mine cause why not?
edit; Im assuming you mean for an emergency, if you're talking convoy comms, then a GMRS handheld will work fine.
JediMcMuffin
Tommy
2021 Bronco Badlands
List out more of your criteria. You just says comms, you don't have say who you're communicating to.
Satellite comms are really nice, especially in a true emergency
HAM is flexible, and certain solutions can even fully cooperate with GMRS
GMRS is cheap and simple
weboost can make your cell signal a little stronger, but there still has to be signal
New Mexico
22 Wildtrax 4 door
All good questions and thank you as it gives me focus. I will be doing mostly day trips, Moab, Colorado mountains. It will be with groups. Used for group comms except there may be the need to communicate with the outside world. Two different applications - probably two different solutions.
I’m thinking GMRS for starters and judge cell coverage while out and about to see if something like a weBoost would even help. Fall back on cell is a Sat phone - expensive.
vrtical
Doug
GSMNP, TN
Fords
you can also look at Starlink "RV" setups, they have one that is a suction cup mount if your really want to cover internet, but a better emergency plan is a Garmin Inreach route.
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
GMRS works very well for groups, but isn't really for emergencies. Part of what makes GMRS nice is the somewhat limited range (on low wattage channels) and the fact it's FM, so you aren't constantly getting blasted by people who are not in your group. There has been some talk of setting up an emergency channel on GMRS in western states, but AFAIK it really hasn't gotten much traction. Other solutions you mentioned would be better for emergency use IMO
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
I have both WeBoost and GMRS and would recommend satellite communication as well depending on where you spend a lot of your time. The WeBoost has it's limits, as you still need a signal. What I find is that it boosts the signal to get a call out when only text go out without it, or to maintain calls without dropping. It also helps to download email, etc. It won't do anything outside the cell area.
I spend a lot of time off the grid, so the Garmin Inreach comes in handy. It's nice to be mobile as I use it for hiking and flying as well.
jrollo7
James
NY
Range Rover Sport
The string is key.
New Mexico
22 Wildtrax 4 door
Would twine work? Cotton or synthetic? What’s the best cup? I have big ears.
604Bronco
British Columbia
www.bronco6g.com
I suggest fishing line and using a large McDonalds cup. The bigger the cup, the longer the range.
New Mexico
22 Wildtrax 4 door
This insight is why I joined the forum.
