Nickp
Nick
Phoenix
Ok so I am going to be "that guy" here.
No offense flip, but I have covered this a year ago so we can call what the Bronco has correctly. It has even been mention in some videos I have watched.
One correction here, it is NOT technically a "strut". It is a coil over. which is a shock with a coil spring "over" it. Hence the name coilover.
A "strut" is an integral part of the suspension. It does the job of the upper control arm by locating the upper part of the knuckle.
"Technically" Ford is the most accurate. "shock absorber assembly" because that is what it is.
This is a "strut" suspension.
THIS is a coil over suspension.
As you can see there is a BIG difference. In a coil over it only has to support the vehicle and dampen the bumps. It is a shock with a coil spring over it. It does NOT locate the upper part of the knuckle. That is the job of the upper arm.
I just want the B6G community to understand what it is they have.
F-150 Coil over, Explorer strut.
As someone who’s significantly more knowledgeable about solid axles vs IFS thank you for this clarification, I’d wondered about the difference but never looked into it.
amccue90
Andrew
Illinois
2021 Badlands
We don't know the specifics of anything else that may be different between the two, but I'm sure takeoffs will be available from BL owners wanting to go with a lift kit, so it's just a matter of time before that question is answered.
What about BL owner mall crawlers like me, might be looking to lower to regain some aerodynamics and agility...
And yes I'm the one who's discussed removing skid plates and other stuff for DD weight savings, only to put back on for offroad planned trips
Rivers90
Ben
california
xterra mx5
11 spring types. wow that is more then I thought there would be. But it shows how the ride for each trim level has been set for the different market that model is aimed at.
I wonder how much these change the handling of each trim model like BD vs. BB.
5280Bronco
Denver
No problem. You could then take the takeoffs from the person buying the other takeoffs and that should hopefully work as well. That clear? Lol
North7
North Texas
SUV
You're only talking about a couple tenths of an inch, maybe 2/10th's, that will not change the aerodynamics and agility in any significant way.
Aviationtech101
Ty
Outback
Im thinking the front a rear control arms may also be different.
BAUS67
redneck
Central PA
I intentionally didn’t post the pics to avoid menutia. Sorry I over thought it.
Don't get me wrong flip I think it is great that you are posting the info. I just want those in B6G to know what it is they have and call it by the correct name.
I work in a 4WD shop and have customers who have NO clue what anything is and it is VERY difficult to explain it to them so they understand. Calling things by their proper name is a good start.
So one good example is wheel offset and backspace. These two things are NOT the same but people think they are. In other words you can't say all +55 wheels are all 6" backspace.
Tires are another thing that is the same way. Everyons classifies 285"s as 33's but nothing is further from the truth because the 285 is the width in MM. Has NOTHING to do with how high the tire is.
Things in vehicles are complicated and when one knows what they are talking about it is easier to understand them and explain differences to them.
So. if you look my name is redneck. That means when you use big words I have to Google them to know what they are. 😁
Ford Bronco More 2021 Bronco Suspension Info & Part Numbers: Standard, Special and High Ride 1623366095634
At least I think that is the word you were trying to use because menutia is a song. 😁
So you may consider this "trivial" , but in my eyes it a HUGE difference in performance and durability.
You will more than likely destroy a strut style suspension if you try to take those whoops like the Bronco does.
flip
flip
Phil
IN
www.ruxerparts.com
Fords
I’m not trying very hard tonight so I must do better with my spelling and correct part descriptions. You win.
BAUS67
redneck
Central PA
:ROFLMAO: :ROFLMAO: Not trying to win ........ just inform.
amccue90
Andrew
Illinois
2021 Badlands
My life is defined by the insignificant.
But base height compared to badlands height (excluding tire difference) only 1/5 if an inch? Now I have to use the search function...
North7
North Texas
SUV
I was quoting the difference in the coilovers, not tires.
amccue90
Andrew
Illinois
2021 Badlands
Right, so are you saying the rest of the height difference is all tires?
.2" plus tires equals overall height lift in badlands
