Exactly! What I was wondering as well, that would be a great product a functional rack and lift point for overhead storageā¦Looks like the perfect rack, you can remove the front roof panels more easily and still utilize the front accessory points for lights or a visor.
How securely does the rack clamp on to the roof? I wonder if you could use the rack as a lift point for removing the rear roof?
It is totally redone and longer designed specifically for the 2 door!
150 dynamic and 300 static! Evenly distributed.what the weight rating on the 2dr and the 4dr?
My 4-dr has increased wind noise after the install of the Trailrax Rack, but not badly so. With both the MIC top and the soft-top, the wind noise increases steadily with vehicle speed: 45mph, very little noise; 55mph, some noise; 65mph worse; 75mph, pretty bad. . . In my experience! But the rack itself is not a primary source of wind noise!Looks good. Have you noticed any change in wind noise at hwy speeds ?
Love the look. And wont interfere with removing the T-tops. How is the wind noise?@Mudlight there is a pad that adheres to the underside of all the mounting brackets keep them from scratching the top (the inside bracket bit you can see in the pic also has a pad against the top). The rear one fits a little better because of the indent in the top. Nevertheless, the front one seems to hold strong and I doubt it can move around. If I grab the top and shake the Bronco around, the top doesnāt move at all. This is a picture a front mount against the top.
That's for a 4DR. This is for 2DRs.I installed this one at less than half that price. Looks to be equal or better quality. Zero noise. https://www.amazon.com/gp/product/B0BQWJ1WNN/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
