SHANUT
Craig
Hermann, MO
Because honestly the 5.0 is not a great engine for this application. Ford's mod motors have to be wound up to get power out of them. Great for the mustang, just eh for the F-150. Almost everyone I know that has had both engines in the F-150 and uses them for truck stuff prefers the ecoboost family. The coyote just has no low end grunt. Even in F-150 configuration, it doesn't make peak torque until over 4K RPM. Don't get me wrong, I love V-8s. The coyote is a good V8 for the mustang. It's an ok V8 for the F-150. I think in the bronco it would be just the wrong tool for the job.
Reason they put it in the DR is because that thing is built for high speed runs.
I couldnā€™t agree with you more. I have a 2018 Mustang GT with the manual transmission and itā€™s a great engine but my F150 is much snappier off the line that has the 2.7 in it. Even my 83 Ford ranger that has an Old-school 302 swapped into it is much stronger at lower RPMs. That being said, if the coyote was an option in the bronco, I definitely wouldā€™ve gotten it because it would be more than enough engine for a small vehicle like that and you canā€™t beat that V-8 sound.
mpeugeot
So you're saying that if I sized the injectors right, my 2.7L map could theoretically run a 3.5L from the GT
Not quite, that has a much larger set of turbos, probably a very different set of cams, etc; but I wouldn't rull it out, just wouldn't expect 600 hp running the 2.7 map. However, the F-150 3.5 probably wouldn't be so difficult (I would have to double check firing order, but I think it's the same).
That has me thinking though, could you get a PCM (blank or otherwise) and load it up with the correct strategy from the 3.0 or 3.5 HO, but then program it with the VIN for a run of the mill bronco for an engine swap using FORSCAN. I think it would involve a little FDRS trickery and some VIN numbers to get the ECU strategies downloaded (but I believe that it is doable).
This would be so much easier if I had a job at Ford working on FDRS. LOL.
CarmeloS
Carmelo
Central Jersey
ā€˜21 2dr Bronco
Plus no replacement for displacement. Not sure where a turbo upgrades and tune can take you power wise, but reliably you could slap on a supercharger making 7-800hp with room to grow (or tops out around 700 for a gen 1 coyote.)
That and a high redline (7400rpm? on a gen 3 or previous gens with intake manifolds/tunes) make it more enticing.
Not saying the 2.7 is bad, but as I see it, bigger engines begin where smaller ones tap out
  • Like
Reactions: Fly
Tex
Cliff
San Angelo
So....what about replacing the turbos with an enormous supercharger
Is that even possible
SHANUT
Craig
Hermann, MO
My son has a 2018 F150 with the coyote that he put a supercharger on and it definitely woke it up but before that it was the runt of the litter compared to the eco-boosts in our family.
BigMeatsBronco
Allan
2021 FE 2 door
This IS the way to do it.
CarGuy
New Jersey
2023 Ford Bronco
I'll offer my Bronco up for 3.5L swap R&D
Let's do this thing
Wouldn't it be easier to bore 2.7 to get 3.5 - if possible. I'm sure there is no stroker kit for the 2.7 and doubt larger Ford V6 cranks, those with greater stroke, would fit the 2.7. :unsure:
lapazleo
Indiana
2022 bronco badlands
I've yet to see the 5.0 swap completed, the OP has had plenty of time to finish.
mpeugeot
find a 3.5EB and drop your truck off here in in Salem...The Bragging rights are almost worth the sweat.
Don't tempt me... I have a Bronco with 93k miles and an F-150 3.5 EB with 250k miles... It would be a trip to put the Tuned 3.5 EB in the Bronco.
CarmeloS
Carmelo
Central Jersey
ā€˜21 2dr Bronco
Hope this becomes mainstream and I can do with a tremec, driving both parents Range Rovers as my girls getting suspension work and after driving Moms RRS Supercharged V8, I need a V8
CarGuy
New Jersey
2023 Ford Bronco
