1.5 inch wheel spacers on Sasquatch?
Stripes136
North Florida
youtube.com
2022 Ford Bronco
Hi Bronco friends – should have my 2022 Outer Banks Sasquatch in production next week 🤞. I like the stance of the Sasquatch but wanted to get your thoughts on adding one and a half inch wheel spacers to give it a little more aggressive look. What are your thoughts on this product?
Live in North Florida so don’t expect to be doing too much rock crawling or stressing the front end.
https://www.cjponyparts.com/wheel-s...f52r4B9w4OF9ZYadijWhw5oQd4KvwV1QaAqWHEALw_wcB
RednWhite89
Evan
DMV
1989 Bronco
Frankie945
Frank
Louisville KY
Q50
I just ordered some 1.5” bora spacers last week. I’d post pics but it’s going to be a month till I get them because they’re made to order. If you get some don’t cheap out get quality spacers and you’ll never have a issue.
Stripes136
Stripes136
North Florida
youtube.com
2022 Ford Bronco
Frankie945
Frank
Louisville KY
Q50
Thanks for the heads up / call out. I will look at those brands.
I’ve bought cheap spacers in the past and not saying your wheels going to fall off but most likely they will give you vibrations due to manufacturing errors when being mass produced in China.
NORCALGXP
Sacramento, California
2017 Raptor
I went with 1" Bora spacer. Have used them before very durable.
BORA TRUCK SPACERS
Bulletproof Off Road Adapters (BORA) are manufactured BY US (no middleman), right here in the USA! We use top-of-the-line, state-of-the-art, HAAS CNC machines, and only the best U.S. Alcoa 6061t6 billet aluminum. Unlike our competitors, we provide a LIFETIME WARRANTY.
https://www.motorsport-tech.com/4DCGI/switchtruckmodel
Ford Bronco 1.5 inch wheel spacers on Sasquatch? 20220111_112249
Ford Bronco 1.5 inch wheel spacers on Sasquatch? 20220111_112142
Stripes136
Stripes136
North Florida
youtube.com
2022 Ford Bronco
BORA TRUCK SPACERS
Thank you and yours looks great. I think I like the 1 inch you have better. Will be ordering them. Do you need an alignment after installing?
Frankie945
Frank
Louisville KY
Q50
BORA TRUCK SPACERS
Did you need to grind off any of the studs or did they fit ok without.
NORCALGXP
2017 Raptor
Did not have an alignment done, probable could use it. I not going to it steer perfectly straight, and if the tires ware out soon great will replace with BFG's A/T.
NORCALGXP
2017 Raptor
The front studs I used my grinder to remove about a 1/16th. On the back used my dremel and cut off about 3/16ths.
Bird Dog Off Road
Jody
Phoenix, AZ
www.youtube.com
Thought about doing spacers, but since my plan is to go with BFG 37s after the 3" lift, i'm worried they may cause rubbing issues.
I used the 1" Bora spacers on my old 5th gen 4Runner and never had any issues. Had them on when I did all the trails in Ouray last summer.
Dave-O
College Station, Tx
F-150/Mach-E
I wonder if they help with keeping rocks away from the body?
Big Diamond
Miles
Atlanta, GA
2022 Bronco HOSS 3.0 Wildtrak
I've ordered the Bora 1" Spacers for my Non squatch BD that I will be putting Sasquatch coil overs on. Does that count?
Benzo520
Ruben
Tucson, AZ
Which lift are you going with?
