I would be entirely deflated. I would likely try to get into another bronco. Clean start.
That would be the best scenario and I would hope ford do that. Talk to ford corporate. The OP was a reservation holder right. That’s gotta have some pull.If OP gets Ford to buy back his Bronco do you really think he wants another?
And if that were the case it would be super nice if the buyback instead worked as an exchange and that Ford would do the job of locating his exact replacement from the field. His as built from factory cannot be that unique that there is not one exact replica in inventory---unless it was a deleted color or trim. For example you would not find a zero mile Antimatter Blue
Agreed. There will always be a dimmer on the enjoyment. Dump it. Get another one. Fun awaits you!Sorry to hear about your trouble but you know what needs to be done. Even if they fix these issues, every time you hear an unnatural sound or feel an unusual vibration or see something under your car in a parking lot, you will be waiting for the other shoe to drop. Tough way to live.
I can’t speak to the oil leak problem, but I had a similar CEL code for engine misfire while on the highway a few months back. Unbeknownst to me, when filling the car up with gas, if you don’t stop pumping as soon as the nozzle clicks, and you try to top off the gas tank, it will mess up something in the fuel system that causes the misfire. Since then, I’ve been careful not to top off the gas tank and have not had the problem again.Hi All,
I've had so much bad luck with the bronco. A while ago I posted about a rear main seal leak and them taking over two months to fix it. Well I took people's advice and brought it to a new dealership. The new dealership (or I guess the FSE[Field Service Engineer] that the legal team sent out to inspect it) decided a new long engine assembly would be a quick fix. I get the car back, and by the time I get home, there's oil visible on the bottom of the bell housing again. Not only that, but now I have an engine light on and blinking intermittently. So I take it back a 3rd time and the FSE says the oil pan may need a new gasket? Not exactly sure if he actually did anything, apparently they lifted it and ran it for 30 mins on rollers or something. Anyways get it back and everything seems fine for a few days. Now I am seeing more oil on bell housing, albeit less than before (no drip, just a stain of oil, but if I wipe it off, it'll come back after driving an hour or so) AND when I give it a good amount of gas i.e. merging onto interstate, the engine light occasionally blinks and I received a notification from Ford pass saying a misfire was detected and I need to take it in ASAP.
I'm at my wits end, I have 11K miles on the 2023 2.7L Bronco, I'm approved for a buyback already via lemon law, but I can't afford to recreate the car since they no longer offer the base/2.7/sasquatch combo. Right now, optimistically, I'm hoping the tiny oil seep is ignorable, and the new engine may just need a simple fix like a part wasn't installed perfectly. Pessimistically, I think they have tried 4 times to fix an oil leak and not only failed but have now given me engine issues and I need to get out of this vehicle before the lemon law buyback option expires. Interested what you all think?
How bad was the oil leak? Granted I would not want an oil leak on my brand new vehicle, but just thinking my old 4x4s all had leaks in various places and were no worse for wear in terms of operation. (For Series Land Rovers it's kind of a norm "marking territory".) Probably if my new Bronco had some very slight hint of oil leak, not sure I would have bothered with it.Hi All,
