Air compressors
beachman101
;pkl
So i see the air compressor on the B/P is pretty good. However if you check the ARB website there are 2 models. A single motor that ford is bundling with the car , and a twin motor. Any off road guys have any opinion on this? is the extra motor worth double the price if mostly you will be filling up 35's?
are there cheaper (and better) alternatives in the aftermarket?
Mostly for sure they will be for filling up tires after a day at the beach
Also not really related. Do you think there is room to mount a fixed model under the hood?
brentutk
Brent
Nashville, TN
Eruption Green Wildtrak
Is the Ford optioned air compressor an installed, mounted on board option? Or is just an accessory in a bag?
Charky
Duane
Little Rock
A7
I have not owned one, but Viair portable compressors are well regarded. Check out the Viair 400P.
beachman101
;pkl
thanks for the suggestion but ARB gets points for a hard case
LandCruiser
Bocephias
CA
Depends on how long you want to stand around kicking rocks while you air back up.
Beachin 74
Delaware
MikeLank20
Chandler, AZ
Challenger SRT, Chevy Equinox
I am personally a fan of the dual arb and mounting it on board somewhere. But there are a bunch of videos on youtube that do time comparisons between single dual and portable ones.
However, you'll still only be as fast as the slowest one in your group.
beachman101
;pkl
fantastic this is just what i was looking for. Seems the dual compressor with a tank will allow you to run tools. However it seems the one ford is selling also has a tank just one compressor.
Might have to get fords version!
MadMan4BamaNATL
Ray
Atlanta
I'll be looking to get a compressor installed. I see people here suggesting compressors that are sold on Amazon. Those ARE NOT what people who go wheeling use.
ARB compressors are by far the best and most durable, so I'll install mine under the hood and connected to my battery. On that note, hope to switch that out to an Optima pretty quickly.
For those wondering about cost, an installed compressor is between $500-$900 depending on the actual compressor. It's not too hard to hook up yourself. You get a long hose basically, get a decent deflator, then keep it moving.
You never go wheeling on road level Psi in your tires. For the 35s I'll have, will try to wheel at 18psi. For rock crawling, down as low as 12psi, but would only do so with bead locks.
beachman101
;pkl
now might be off topic but can you explain bead locks to me. I know what they do but i dont understand the benefits to them regarding off roading
Also dual or single compressor? should i skip the ford one and get it installed in the hood?
JesseS
Jesse
Northern California
Jayco AY26, Honda F6B, CR-V
Good luck installing it under the hood, not a lot of room and a duel motor compressor isn't exactly small. I have a baged single motor ARB w/digital chuck for my RV's 19.5" tires, and it works well, so I will just through it in the back under the seat.
