- JAKE
- Jan 12, 2023
- 2
- 9
- 35
- MADISON,OH
- 2022 FORD BRONCO 22 FORD F150
- Outer Banks
Yes go to your local dealer shop and tell them to update your sync. They should keep the latest software version on a usb drive. This should be done at no cost if youāre under 3 years and 36,000 miles!Is there a way to force sync software updates? Mine is on powerup 1.6 and hasnāt updated since last April. Both automatic and scheduled updates are turned on and nothing ever happens.
Developed a month or so after receivingDo you have a photo? Was a manufacturers defect?
You missed this oneAny new news regarding this issue?
SSM 51166 2021-2022 Bronco - Headlamps Turn On By Themselves When Vehicle Is Off - DTC B1533
Some 2021-2022 Bronco vehicles may exhibit a condition of intermittent headlamp operation while the vehicle is OFF and have diagnostic trouble code (DTC) B1533 stored in the body control module (BCM). This may be due to the internal logic within the headlamp switch. To correct this condition, replace the headlamp switch (service base PN: 11654). Refer Workshop Manual, Section 417-01.
This is a common issue, search for other threads about itDeveloped a month or so after receiving
1400Sport mode will increase aggression in your shifting patterns. How many miles are on the vehicle ?
I saw this someone ask this in another thread so I'm curious.Posting this thread to be helpful for any warranty issues. I work at a ford dealer in north east Ohio, drive a bronco myself and have access to all TSB (technical service bulletins), Recalls, and portal messages. As well as the issues I see on the daily! feel free to conversate.
Mineās at my dealer for some modem/TCU issue. I mentioned the same steering wheel issue. They replaced it without any problems.Developed a month or so after receiving
