- Matthew
- Dec 14, 2021
- 8
- 127
- 443
- Sarasota, FL
- Website
- www.srqfabrications.com
- 2021 Bronco 2Dr
- Wildtrak
Check the 4 bolts that hold the hinge assembly to the shell and the frame support underneath. If these are loose at all you will have play in the hinge assembly and cause the swingout to angle down.No, once it becomes unlocked the weight bends the bracket and or mounting pin. I’ll need to disassemble to find the exact problem but I have to lift the tire swingout get it closed now. I’ve had numerous bumpers with dual swingouts and this is the first one that’s ever given me issues. After yesterday I honestly feel the tailgate, with the brace, was stronger than this. I had run probably around 50 trails with the tire on a braced tailgate and no issues, the first trail I do with this bumper and I’ve got serious problems.
Once these bolts are loose, it is easy to bend the t-handle lock on the hinge since the weight of the swingout will rest on it and it's not designed to hold that weight.
The whole top and center section of the bumper is made out of 3/16" steel. The only parts that are 1/8" steel are the wings on the end.
Are you running just the 37" tire? Or do you have a basket on top of the tire with more stuff in it? I would not recommend running anything but the wheel/tire combo on the passenger-side swingout. The 37" tire alone is a lot of weight.
ADDITIONAL EDIT:
We have been working on adding support to the assembly that ties the swingout to the frame under the bumper. I can add some photos shortly. We are happy to send you an updated version if you plan to continue to run extra weight on the passenger swingout. There is an additional 1/4" plate running the length of the assembly helping tie the 2x2x3/16" square tubing in direct to where the assembly meets the shell of the bumper.
Would like to add that we can only do so much testing on products. We do relying on customer feedback to make adjustments and better the product as a whole. Whenever we do get feedback that requires changes to the design we implement them and offer the updated versions to those already with the product. We appreciate the support from the Bronco community and work hard to offer the best product possible.
