tool to remove wipers?
rret
rick
ct
frontier, jetta
can anyone recommend a tool to remove the wipers? something that is actually known to work? ('car' is a Bronco base.) Thanks.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Iā€™ve been considering a rear wiper delete and curious on what that entailsā€¦
GreyZ
Gulf South Louisiana
Turbo 350z, Bronco Badlands, Xterra
For the front or rear? For the fronts you should be able to remove the nut and then a good tap with a db mallet on the hinge location should pop it off.
any part store should be able to rent the puller, but in my experience I havenever needed one.
rret
rick
ct
frontier, jetta
yeah that didn't work on my Bronco. The arms are super tight. Can anyone recommend a puller that actually works (fits down in there too)? I'd even buy a Ford tool but can't find that either.
Moto26
Tucson AZ
I was looking at this recently, too. I havenā€™t pulled the trigger, but it seems you need something like thisā€¦
https://www.amazon.com/OTUAYAUTO-Battery-Terminal-Wiper-Puller/dp/B076PY8785/ref=sr_1_13?crid=RPTBWDYL0L3R&keywords=2+arm+puller&qid=1683062591&sprefix=2+arm+puller,aps,219&sr=8-13
Thatā€™s what I thought, until I tried it. Good luck!
JohnnyBronco
Pennsylania
X4
Try a small battery terminal puller. Or a small pickle wrench, applying upward pressure while you tap the post --and please place a disposable nut back onto the threads before tapping or you may ruin the threads and will be adding a thread chaser to your toolbox.
And don't be in such a hurry, apply WD40 or better liberally overnight
Failing the above if you are replacing the arms with something else then a mini Dremel type or oscillating tool will slice right through the arm you are trashing anyway
