Will 36" tire fit on sasquatch package without tire rub?
Broncridin
James
Houston Texas
Ram 1500
I'm looking at putting LT315/70R18 's on my First Edition 4 door. Has anyone done this ? Any pics? I may get a leveling kit for the front but not sure if that is needed or would help. Would like to see what that set up looks like if anyone has already done it. Toyo LT315/70R18. 35.7" MT
Theherofails
Thomas
Phoenix
You can fit true 37s with very little to no rub, depending on backspacing. Worst case is you trim where the crash bar was a little.
Are you saying that you're upgrading wheels AND tires?
Gamecock
Did you do it? That’s not why others are saying…have any pics?
Theherofails
Thomas
Phoenix
I JUST saw one of the bigger YouTubers do this without the BC spacer everyone is using. Let me see if I can find it. The only issue was slight rubbing where the crash bars would connect, but he used a different offset than factory to clear it. You still need to modify bump stops.
I believe they were Method wheels but I couldn't begin to tell you the backspacing.
Still looking for the spacing. Here is an example of the slight rubbing you get with factory backspacing. Weve had a few members run it this way without too much issue. Most end up doing the spacers to keep the factory wheels.
https://www.bronco6g.com/37s-fitted-on-sasquatch-bronco-straight-off-the-transport/
Not the right video yet, but more examples.
Bradley Thornton
Bradley
Hattiesburg MS
